battery usage is horrible - how to optimize
tonyvr4
190
I am in the process of transferring apps. data and so on from a Galaxy Note 9 to a Galaxy S21 Ultra
There is some issues but the biggest seems to be the horrible battery usage.
The Note 9 had a power mode under battery/power mode mine is set to optimized
I can not find a similar setting on the S21 Ultra.
Can anyone advise?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,555
6,132
113
You have to long press each app >tap info>tap battery can change there , dont transfer settings over coming from different Android version and battery will take a hit for first few days until everything settles and learns your usage
tonyvr4
190
In settings/apps I can press on any app for more settings but long press does not work
Roadijeff
199
33
28
Can anyone advise?
The S21 Ultra has a power saving switch under Settings > Battery and device care > Battery > Power saving
tonyvr4
190
I am concerned as to why a S21 Ultra with a 5000 mAh battery gets poorer battery time than a Note 9 with a 4000 mAh battery ?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,555
6,132
113
I am using a different launcher so it looks different. When I long press on an app I get options and one of those is a circle with an ! in it.
That brings up app info
But do you mean I have to change every app to optimize?
Yes in Android 12 probably was Android 11 also
You'll have 3 selections it's no longer available in settings>apps>3 dots upper right corner>battery optimize
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,555
6,132
113
Note 9 had only 60zh panel and was one the best battery Life I had on that device 11 to 12 SOT a day battery
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,555
6,132
113
You want have similar results
FHD screen resolution
Drop to 60 hz
Turn 5g off
Leave automatic brightness
Turn AOD off
