1. Shellcracker's Avatar
    It seems my charging port will need repairing, so until then, i am going to charge wirelessly. I didn't want to break bank for a wireless charger. Saw this one for ~$26 bucks. Anyone else use it? I saw some others that were cheaper and higher W output, but they were store brand so i disnt feel comfoetable with them.
    Anker has a good reputation as a 3rd party charging accessory supplier don't they? Would habe preffered a stand but they didnt have any. So pad it is.
    Attached Thumbnails How is this wireless charger for S22, is it good enough?-20220926_150840.jpg
    09-26-2022 04:31 PM
  2. mustang7757's Avatar
    Anker good brand but highest the s22 will charge wirelessly is 15w
    Laura Knotek likes this.
    09-26-2022 04:49 PM
  3. mustang7757's Avatar
    I got the Samsung 15w 89.00 its expensive but does all my devices How is this wireless charger for S22, is it good enough?-pxl_20220926_205235966.jpg
    I am the Liquor likes this.
    09-26-2022 04:53 PM
  4. Wiley_11's Avatar
    This is what I use, works great. ~$30
    https://www.amazon.com/Google-Wirele...cUvbUpU7104070
    09-26-2022 09:44 PM
  5. Aredubu's Avatar
    https://www.amazon.com/Google-Wirele...cUvbUpU7104072
    I have both the OG Pixel charging stand and the 2nd generation and both do just fine on my S22U.
    09-26-2022 09:55 PM
  6. trucksmoveamerica#AC's Avatar
    This is one of the reasons I use a wireless charger as much as possible, to avoid damaging the charger port. I think the micro USB ports are easier to damage then type C, so probably not as big of an issue now.
    I would think the Anker would work fine. The only thing I can suggest is to check with Anker and see if it keeps trickle charging when the phone is fully charged. I used an Anker portable battery power bank and worked great, last year I bought a new Anker power bank and once the phone fully charged it stopped charging and I would wake to a less then fully charged phone. Anker said they changed them, the new ones stop charging.
    I use the Samsung like mustang posted above, works great. Also, remember on these wireless chargers, the cord and charger brick do make a difference. Using cheap cords and bricks won't always power the wireless charger.
    Laura Knotek and Shellcracker like this.
    09-27-2022 06:03 AM
  7. gtt1's Avatar
    This is one of the reasons I use a wireless charger as much as possible, to avoid damaging the charger port. I think the micro USB ports are easier to damage then type C.
    Can you explain this? I was under the impression the S22 charge port was USB C. What does a micro usb have to do with S22?
    09-27-2022 09:26 AM
  8. kixfan's Avatar
    How is this wireless charger for S22, is it good enough?-thumbnail_20220927_125356.jpg
    https://www.amazon.com/gp/product/B0...cUvbUpU7104201
    I use this one. It charges my phone, watch, and earbuds all at once if need be. Paid $30 for it.
    Shellcracker likes this.
    09-27-2022 01:01 PM
  9. tismydroid's Avatar
    I believe the point he was making is that the S22's USB-C port is not as delicate as the previous micro-usb ports but that when you wireless charge you don't risk damaging the port.
    09-27-2022 03:27 PM
  10. trucksmoveamerica#AC's Avatar
    I'll explain better for you. I was saying that the micro USB ports break easier in my experience. I am very well aware that the S22 is type C, type C has been around for awhile. I am saying that type C IMO (In My Opinion) is better and don't break as easy.
    So to explain it better for you, I was comparing the 2
    09-27-2022 03:28 PM
  11. trucksmoveamerica#AC's Avatar
    Thank you.
    tismydroid likes this.
    09-27-2022 03:30 PM
  12. Shellcracker's Avatar
    Pretty happy with this pad. Its only 10w charging, but the speed is respectable enough for me and the rubber coating keeps it from sliding off real easy, works theough my case too. From 10% itll get me back up to 80% in about 1 hr 30 to 1hr 40 mins depending on how centered up I have the phone on the pad. And it being a thin pad makes it ergonomical and doesnt take a lot of space.
    Overall, id give it a good 8/10 and feel its worth the $25 or so after taxes i paid for it. The only true fuss I have is it is still using a micro-USB connector going into the pad, while USB C to USB C has become the standard now. But it still gets the job done plenty well enough for my needs.
    09-29-2022 08:21 PM
  1. Replies: 3
    Last Post: 09-27-2022, 09:34 PM
  2. Why is com.sec.android.app.camera popping up in the middle of the night?
    By sirsnicks in forum General Help and How To
    Last Post: 09-27-2022, 10:00 AM
  3. Is IN2017_11_C.41 Stable for rooting OnePlus 8?
    By DopeSaladz in forum OnePlus 8 & OnePlus 8 Pro
    Last Post: 09-26-2022, 08:30 PM
