1. chris_j11's Avatar
    SGH-I747M rooted, but still original rom
    Carrier - Rogers
    Device type - d2can
    Bootloader/Baseband/PDA- I747MVLDLK4
    Modem board- MSM8960
    CWM-based Recovery v5.5.0.4
    i've been wanting to install cm12 rom on my phone for the longest time and this morning i decided to jump into it (i did spend time reading some info here and there and getting advised getting the matrixzone rom)
    my first mistake was i decided to unlock my bootloaded with ez-unlock - this caused my phone to hard brick
    i found a link in XDA section ([HOW TO GUIDE] How To Unbrick AT&T I747 and I747M After 4.3 OTA) to help me boot back to my phone from my sd card
    then my second mistake - used another link in XDA section ( [HOWTO] [ROOT] No Tripping Flash Counter - [ATT / Bell / Telus / Rogers / Sasktel]) above to download the stock Rogers 4.1.1 and load to Odin
    Started Odin and it failed right away - now my phone will only go Odin mode with "Firmware upgrade encountered an issue" messages at the bottom
    I was informed to go to sammobile to download a newer firmware (not sure which one) and try again with Odin
    i decided to download the latest Roger version 4.4.2 - still waiting for it to finished
    anyone else can provide help will be very much appreciated = thanks in advance
    06-21-2015 06:48 PM
  2. leegreg81's Avatar
    In order for ODIN to connect to your device you'll have to put it in DOWNLOAD MODE:
    1. Unplug the USB cable.
    2. Shut down the phone.
    3. Hold down the 'HOME' + 'VOLUME DOWN' buttons and press the 'POWER' button for about 2 seconds until a WARNING! Screen appears. Press the 'VOLUME UP' button to enter Download Mode.
    4. To get out of Download Mode, simply press and hold the power button until the phone restarts.
    06-21-2015 06:57 PM
  3. chris_j11's Avatar
    yes i'm in odin mode
    after i press volume down+home then power it gets to warning and ask me to press volume up
    i tried a higher rom 4.1.2 -Odin Fail!
    I will now try a much higher rom at sammobile - 4.4.2
    06-21-2015 07:45 PM
  4. leegreg81's Avatar
    Are you attempting to flash a stock ROM?
    06-21-2015 08:26 PM
  5. chris_j11's Avatar
    well sucess - download the latest sammobile 4.4.2 and used Odin to install.
    after 30mins my phones back to normal
    thanks for all the help - now i'm more confident
    now i will try to root / install cwm / and continue with matrixzone w/ a twist - hope to have a better result
    06-21-2015 08:43 PM
  6. milo williamson's Avatar
    In the same boat, after nearly trying to flash my phone, it suddenly went to the Firmware screen...
    07-05-2015 06:35 PM
  1. Moto E 2015 (or XT1526) flashing issues
    By Eric McElfresh in forum Moto E (2015)
    Last Post: 12-22-2016, 01:09 AM
  2. I don't have instagram but it keeps popping up on my screen
    Last Post: 06-24-2015, 07:28 AM
  3. android upgrade
    By shivam gupta8 in forum Ask a Question
    Last Post: 06-24-2015, 07:26 AM
  4. Upgrading phone, need help!
    Last Post: 06-21-2015, 06:09 PM
  5. How to move from an Samsung s5 to an iphone
    Last Post: 06-21-2015, 05:45 PM
