1. Dara McCormack's Avatar
    Since the last update a few months back I've found that the drop-down menu bar at the top of the screen regularly freezes up and won't drop down...a reboot solves this but its a bit of a pain in the face!! I have the odd freezing issue now and again but nothing major, there's a fair bit of stuff on the phone, but this drop down menu one has been ongoing and only since the update.
    Also I have an external memory card on which I used to be able to store all photos on automatically, however one day for some reason I got a message saying that the photos cannot be stored on external memory, again I rebooted, checked and changed all the settings etc. but still doesn't do it...not sure why?!! I don't see a way to transfer files from the internal to external storage?
    I have factory reset the phone since both these faults appeared and occurred and they are still keep cropping up. Any ideas?!
    OS is android 4.1.2
    Thanks,
    Dara
    08-23-2013 05:14 PM
  2. Golfdriver97's Avatar
    OS is android 4.1.2
    Thanks,
    Dara
    Welcome to the forums!
    You can try rebooting into recovery and clearing cache. I don't know if the method I will provide will work, but you can give it a try. Here: http://forums.androidcentral.com/sam...2-s3-tab2.html
    Dara McCormack likes this.
    08-23-2013 05:31 PM
  3. Igor Kontorovich's Avatar
    Hi!
    Alias, my s3mini gets stuck at least twice a day now. I have noticed that every time after the restart I get notifications about program updates from Play store. Can these things be related?
    What do you think?
    08-24-2013 02:42 AM
  4. Dara McCormack's Avatar
    Hi, thanks for the replies!
    I did the reboot and cleared the cache just last night, hopefully that will work. Although I did a factory reset previously and still have the same problem, really only is since the update to the current software version.
    I did however sort out my SD card issue! I shutdown, pulled out the card popped it in again, had a few issues with it initially, messages telling me the SD card was blank or had unsupported something (files on it I presume as I couldn't read the message in the drop-down menu!!) anyway after 2 or 3 reboots it started to work again so one problem solved!
    Igor as far as I can see you need to regularly clear the cache and tidy up old texts etc. to keep these phones running...
    Golfdriver97 likes this.
    08-24-2013 03:33 AM
  5. Golfdriver97's Avatar
    Good to know. Thanks for posting what fixed your problem. Let us know if the cache clear worked, too.
    08-24-2013 09:06 AM
  6. talha Farooq's Avatar
    When I open my s voice in s3 mini and speak any command it says ''no network connection connect and tyr again" although I am connected to Internet
    Please help me
    THANKS
    09-16-2013 11:58 AM
  7. MancevaSanja's Avatar
    hi guys please help me. I have problem with touch wiz. Maybe every day my phone start to blink several times and then it blocked and said touch wiz isn't responding ??? please help
    09-23-2013 08:07 AM
  8. Calvin Reabow's Avatar
    My samsung galaxy s3 mini is almost a year old now, but recently has started to turn off randomly and instantly turn back on but with like 1% battery life eg: it will be 80% battery life but then will all of a sudden turn of and turn back on with 2%, but when you turn it off and charge it, it has 80% still. What do you suggest is wrong?
    06-10-2014 11:49 AM
  9. Md Faisal's Avatar
    I have s3 mini mobile and not receiving calls sometimes and when I restart mobile and getting missed call aler
    Lunetic Ovi likes this.
    08-05-2014 04:19 AM
  10. mark_lennon's Avatar
    hi, will you please help me with my problem with my samsung galaxy s3 mini? when i go to hard reset ( pressing VOLUME UP + HOME KEY + POWER BUTTON ) it only stay with the logo and nothing more... i reprogrammed it many times in ODIN mode and it said passed but still the same case happened... please help me..
    01-09-2016 10:48 PM
  1. Tunein radio problem
    By Patrick Williams13 in forum HTC One M7
    Last Post: 04-27-2016, 04:55 PM
  2. Wierd problem - help!!??
    By gbrown227 in forum Samsung Galaxy S3
    Last Post: 08-24-2013, 01:22 PM
  3. How do you autodial voice mail on Mini?
    By Rip in forum Motorola Droid Mini
    Last Post: 08-23-2013, 01:29 PM
  4. Samsung s4 - 19500 problem recording with vine
    By jimixxxpoker in forum Samsung Galaxy S4
    Last Post: 08-23-2013, 09:27 AM
