1. mbrn2's Avatar
    Hello!
    Several days ago (I don't remember exactly when) I got message about firmware update, which I applied when I got to wi-fi and plugged my phone into the charger.
    Few days later, battery started to act odd (not really the battery, but its icon to be precise):
    - sometimes it says "Charged 100%" (or Charging if any other percentage) after unplugging it and the battery icon still has the "thunder"
    - No sound when plugging out
    - sometimes it returns to normal after a while, sometimes not
    I reckoned it could be related to firmware update, so I went to Settings>About device>Software update>Check for updates in order to check if there's a fix, but I got the message: "Your device has been modified. Software updates are not available."
    But what does it mean? I have never done any modifications on the device, at least that I'm aware of. I don't use odd applications, and I don't even know what is root and what does it do, so I reckon I haven't performed it.
    Was the firmware update some kind of scam?
    What can I do to fix it?
    Model number is GT-I18190N, Android 4.1.2.
    Please help...
    10-10-2014 02:51 PM
  2. GSDer's Avatar
    Hello and welcome to the forums!
    4.1.2 does appear to be the latest stock firmware available for your model http://samsung-updates.com/device/?id=GT-I8190N but it does sound like something got borked when you loaded the recent update. You could try using the Kies software to reload the firmware or you could use a tool called Odin to manually load it.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    10-13-2014 03:55 PM
  3. mbrn2's Avatar
    Hi!
    Thanks for the welcome and the reply.
    Now when I check for the updates, it says that it is up to date. I no longer get the modification message. Could the problem be mechanical instead of software related?
    I still have the warranty for the device.
    10-13-2014 04:08 PM
  4. GSDer's Avatar
    I'd recommend booting into Recovery mode and clearing the system cache and performing a Factory Reset - that should take care of any squirrelly behavior. (Be sure to backup your data using the Kies software or your tools of preference first.)
    10-17-2014 08:57 PM
  1. Set alarm clock for once only. Not 6 days from now?
    By dodger009 in forum Samsung Galaxy S4
    Last Post: 07-10-2015, 07:23 PM
  2. Note 4 Suggestions needed for a Parental Control App?
    By Honey_184 in forum Samsung Galaxy Note 4
    Last Post: 11-25-2014, 11:59 AM
  3. Android L for Nexus 4?
    By chins22 in forum Google Nexus 4
    Last Post: 10-14-2014, 07:09 PM
  4. My Alcatel one touch DL600 Digicel phone is stuck at start up screen..
    By Dave Herbert in forum General Help and How To
    Last Post: 10-11-2014, 10:03 PM
  5. Replies: 1
    Last Post: 10-10-2014, 05:23 PM
