Originally Posted by
Ivan Piacun At least I am noticing it on the Samsung S3 Mini. I have tried everything to fix it. Settings changes do not work. Ending the App only stops it for a little while and then it comes back again. Closing the app with the lower right button on the phone leaves it running. Uninstalling the app's updates works but only until the next update of the app in the course of normal Google Play updates. There is no way of disabling this particular app from updating on Google play on this phone this I needed to turn off automatic updates and get notified whenever an app requires updates and then just manually select applications except for Google Play to update. Which is a real nuisance and a waste of my time.
In my opinion when you close an application with the right lower button on the Samsung S3 mini it should end it. If I wanted it to run in the background I would close it with the center lower button.
I have reported this as an abuse of my phone on the Goggle Play options for this application yesterday but the update that came through today does not appear to have fixed the problem. Is Google in collusion with phone manufacturers to sell new phones so that we can have the option of disabling individual app updates in Google Play.
It's not updating 24/7:
When you open and close App #1
- Android keeps process of App #1 in cache
Open and close App #2
- Android keeps process of App #2 in cache
Open App #1? Android has the process in cache, saved time there.
It's actually a bit more complicated. Please read:
http://forums.androidcentral.com/amb...m-android.html
Swyped from my Samsung Galaxy SIII mini (GT-I8190) - via Android Central App
