1. Justin Hepton's Avatar
    Hello everyone,
    I have a samsung galaxy s3 mini and after leaving it on charge overnight, I wake up and its dead! No response, no graphic when I plug in the charger, nothing.
    I just dont know what to do. Ive tried going into recovery mode (power button, volume up and the home key) but nothing. I tried that with the volume down key with the same result. This phone is less than four months old!!!
    I apologise im not hugely tech savvy, so if anyone wants to ask me anything in order to help, please do!
    Im so pi$$ed of its happened again. Id SO appreciate any help!
    Justin
    03-24-2015 01:07 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try a new or different battery, in case the one you have is defective.
    03-24-2015 03:16 PM
  3. Justin Hepton's Avatar
    thanks b diddy! Unfortunately ive tried that with the same result. No luck. Any other ideas at all?
    Justin
    03-25-2015 09:03 AM
  4. B. Diddy's Avatar
    Contact Samsung, if it's still under warranty.
    Are you saying the exact same thing happened with a previous S3? I suppose some app you keep installing could cause similar problems, although I doubt it could cause it to completely shut down and not be able to power on. Is the phone usually plugged directly in a wall outlet? Maybe you're getting power surges that are frying the phone's circuitry. Try using a surge protector.
    03-25-2015 10:31 AM
  1. Replies: 2
    Last Post: 03-25-2015, 12:05 AM
  2. Replies: 2
    Last Post: 03-24-2015, 05:16 PM
  3. Replies: 1
    Last Post: 03-24-2015, 02:06 PM
  4. How can I uninstall updates to the Google Play store app?
    By AC Question in forum Google Play Store
    Last Post: 03-24-2015, 01:03 PM
  5. What are the limitations of CM12 for Samsung Galaxy Note 2?
    By Ghost Hood in forum Samsung Galaxy Note 2
    Last Post: 03-24-2015, 12:47 PM
