Over the past couple of months, I’ve spend countless hours trying to get my phone to work properly on Virgin Mobile’s network. For those of you who have ever attempted to flash a newer version of Android onto your phone, you’ve probably found yourself in a similar situation. That’s precisely why I have taken the time to write this post. I finally found a solution to this problem and decided to share it with the community. Your welcome everyone!
Onto the most important piece of this post—the actual solution. For those of you keen on flashing things, I created a ZIP package that you can install using either ClockworkMod or TWRP. It is designed to fix the following issues that many popular ROMs have:
Directions:
Downloads:
File Name: "vmu-apn-patch.zip"
MD5: 7BF4BD3370CD3C3C3EABE93AD492DC55
Link: https://onedrive.live.com/redir?resid=9589CE1DB53562DD!5950&authkey=!AChog-_qpGDA5xc&ithint=file,zip
I would like to give a special shout-out to MopedRyder over on AndroidForms. This APN patch is based on a similar one that he made for Android KitKat (4.4). You can check it out here.
- Wrong carrier name – Some ROMs show “Sprint” as your carrier instead of “Virgin Mobile”.
- Broken LTE – Most ROMs are not able to establish an LTE connection to nearby cell towers.
- Broken MMS – Most ROMs are not configured to handle MMS (text messages with attachments) properly. This typically prevents the default text messaging application from downloading and sending MMS messages.
- MMS messages cannot be sent over LTE using the AOSP messaging application
- Group messaging (which also relies on MMS) does not work in the AOSP messaging application
- Android is sometimes unable to switch between LTE, 3G, and 2G when the preferred network type is set to LTE. This is most likely a compatibility issue with the modem firmware and newer versions of Android.
Directions:
- Boot phone into recovery mode
- Flash your favorite ROM
- Flash the APN patch / ZIP package
- Boot into Android and get past the welcome screens (if applicable)
- Wait a few minutes for the telephony database to be rebuilt
Downloads:
