1. ska009's Avatar
    hello
    after to try the un officiel version of android 5.1 I was want to back the original version 4.3 jeally bean the I begin flash my phone with the rom officiel with odin V 3.10 what happened is whan it was flashed the computer off in 90% of flashing system I get a failed flash I repeat the instruction and the flash passed good but no sounds or sim card working I reflash it with other version officiel annd unoficiel but I get the some problem
    I need a help please thank you
    08-16-2016 05:12 PM
  2. B. Diddy's Avatar
    Moved to the AT&T S3 Rooting forum.
    08-17-2016 04:19 AM
  3. ska009's Avatar
    no replay !!!!
    08-19-2016 04:30 PM
  4. B. Diddy's Avatar
    Ok, I'll try moving this to the general S3 Rooting forum (since the carrier-specific rooting forums probably aren't as widely viewed).
    08-20-2016 04:35 AM
  1. Underwater Review of the Galaxy Note 7 (VIDEO)
    By smooth4lyfe in forum Samsung Galaxy Note 7
    Last Post: 08-17-2016, 08:40 AM
  2. will the galaxy note 7 be compatible with project fi ?
    By Goosinurwife in forum Samsung Galaxy Note 7
    Last Post: 08-16-2016, 10:07 PM
  3. Replies: 2
    Last Post: 08-16-2016, 06:56 PM
  4. How do I delete a contact from my Galaxy S3?
    Last Post: 08-16-2016, 04:48 PM
  5. Galaxy note pro Wilmot update
