1. TheMujka's Avatar
    Hello,
    I am using a Samsung Galaxy S3 GT-I9300.
    I deleted my ROM and decided to install android 4.3
    I downloaded the ROM from the official Samsung website and installed Odin.
    I've already done this so I haven't backed up anything.
    I wiped all data and cache and went into download mode and started to flash it.
    The bar (both in Odin and on the mobile device) fills up to third (1/3) of the way and just stops.
    I've left it for several hours, it doesn't move.
    I've downloaded multiple versions of Kies in hopes to reverse everything, it doesn't connect my device to the program though.
    Now I am stuck.
    I think I have accidentally disconnected the USB cable in the middle of flashing the ROM so it stopped.
    Every time I try again, the same thing happens, the bar goes up to the same point (one third of the way) and stops.
    I can't boot up the device, the only 2 things I can get access to is:
    -Download mode
    -Screen where it says "Firmware upgrade encountered an issue. Please select recovery mode in Kies & try again"
    PELASE HELP ME
    12-07-2017 06:00 PM
  2. Rukbat's Avatar
    It sounds as if the phone had been updated past 4.3 at one point. Have you tried to flash 4.4.2? Or whatever version was in it before?
    12-07-2017 09:26 PM
  1. Why can't i make calls on my tablet
    Last Post: 12-07-2017, 09:20 PM
  2. Always on display and screen burn in with pixel 2 xl?
    By kpatel85 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 12-07-2017, 09:06 PM
  3. Why can't I open a off file on my Android Samsung 7
    Last Post: 12-07-2017, 06:38 PM
  4. Kindle app on my tab will not open amy book at the last page read. Why?
    Last Post: 12-07-2017, 05:41 PM
  5. Replies: 0
    Last Post: 12-07-2017, 05:04 PM
