1. npiomar2's Avatar
    Good day.
    My device was first rooted and I already flashed a custom rom on it so I decided to remove the root . When I connect it on my pc, my pc cannot recognize my phone because of the custom rom that I flashed thats why I decided to wipe or factory reset but it doesent work. so i explore the recovery mode then i accedentally deleted my os and i dont have a back up for it. is there any way that i can flash a os on my phone?
    08-18-2019 10:12 PM
  2. mustang7757's Avatar
    Hi, welcome!
    You know how to use Odin?
    npiomar2 likes this.
    08-18-2019 10:15 PM
  3. npiomar2's Avatar
    yes. but my pc cant recognize my phone
    08-18-2019 10:29 PM
  4. mustang7757's Avatar
    When you start Odin and plug your phone dont say com in the box ? If not try reinstalling the Samsung drivers again
    08-18-2019 10:32 PM
  5. npiomar2's Avatar
    no. nothing shows on Odin. but theres a notif from my pc that the the windows cannot recognize the previous edvice connected. maybe it because of the custom rom that my pc cant recognize my device
    i guess
    mustang7757 likes this.
    08-18-2019 10:35 PM
  6. mustang7757's Avatar
    i guess
    I'm not sure , you said you erase the OS , but now you saying its custom ?
    Have you tried reinstalling the Samsung drivers ?
    08-18-2019 10:41 PM
  7. npiomar2's Avatar
    ill try re installing it now. thanks
    08-18-2019 10:43 PM
  8. mustang7757's Avatar
    Ok
    08-18-2019 10:44 PM
  9. npiomar2's Avatar
    it only shows this
    08-18-2019 10:48 PM
  10. mustang7757's Avatar
    it only shows this
    But you tried to reinstall the drivers ?
    08-18-2019 10:50 PM
  11. npiomar2's Avatar
    yes.
    08-18-2019 10:50 PM
  12. mustang7757's Avatar
    yes.
    Maybe restart your computer and try plugging phone again
    08-18-2019 10:53 PM
  13. npiomar2's Avatar
    ok..
    08-18-2019 10:55 PM
  14. npiomar2's Avatar
    still the same
    08-18-2019 11:05 PM
  15. mustang7757's Avatar
    still the same
    You will need to take it to phone repair center
    08-18-2019 11:06 PM
  16. npiomar2's Avatar
    ok. can i flash stock os using external memory?
    08-18-2019 11:09 PM
  17. mustang7757's Avatar
    How do plan to do that ?
    08-18-2019 11:09 PM
  18. npiomar2's Avatar
    download os then copy it to my sd card then flash it using twrp recovery?
    08-18-2019 11:11 PM
  19. mustang7757's Avatar
    It's worth a try , yes try that first if that's successful then see if Odin can see the phone and flash to stock firmware
    08-18-2019 11:15 PM
  20. npiomar2's Avatar
    dont know where to find os hehe.
    08-18-2019 11:21 PM
  21. npiomar2's Avatar
    i have a friend that has the same phone model like mine. if i back up his os then put it in my sd card then recover it in my phone?
    08-18-2019 11:22 PM
  22. mustang7757's Avatar
    Oh ok good, let me know how u make out
    08-18-2019 11:28 PM
  1. How can I delete contacts from my Bluetooth?
    By bignloud65 in forum General Help and How To
    Last Post: 08-31-2019, 06:01 PM
  2. samsung j120a (j3) google locked no sim card cannot get in please help,,,,,
    Last Post: 08-19-2019, 02:04 AM
  3. Replies: 2
    Last Post: 08-18-2019, 05:07 PM
  4. need help with Android TV box
    By willsp1983 in forum Android TV
    Last Post: 08-18-2019, 01:30 PM
  5. need help with Android TV box
    By willsp1983 in forum Ask a Question
    Last Post: 08-18-2019, 12:15 PM
