02-23-2013 04:14 AM
48 12
tools
  1. DanBa's Avatar
    Samsung Galaxy S III & affordable tiny Stoner Acoustics UD100:
    www.hardwarezone.com.sg - View Single Post - so happi i jumped boat... how bout u?
    Tiny DAC, Big Sound
    Stoner Acoustics
    stock Galaxy S III > digital USB audio out >> UD100 >> Sennheiser IE80
    Like the ODAC, the heart of the Stoner Acoustics UD100 is the 24-bit ESS Sabre conversion chip.
    http://www.esstech.com/PDF/ES9023%20...B%20110117.pdf
    09-23-2012 04:29 AM
  2. DanBa's Avatar
    Samsung Galaxy S3 & xDuoo XP-1 USB DAC/amp:
    Report
    xDuoo XP-1
    stock Galaxy S3 > digital USB audio out >> xDuoo XP-1 >> headphones
    09-27-2012 04:07 PM
  3. DanBa's Avatar
    AudioQuest Bumblebee Android DAC:
    AUDIOQUEST BUMBLEBEE || AVLAND UK information, pictures & spec for the
    "Designed specifically for Android devices
    Supports all music files including 24-bit/192kHz lossless
    Drives headphones directly with 3.5mm mini-jack output
    Fixed or Variable output modes
    Asynchronous transfer for accurate digital timing
    64-position (computer-controlled) analog volume control
    Isolated dual master clocks
    Colour changing LED to indicate source sample rate"
    I am wondering if the AudioQuest Bumblebee Android DAC is a standard self-powered USB DAC or an Android-specific USB DAC.
    Android phones and USB DACs
    The AudioQuest Bumblebee should be likely an AudioQuest DragonFly with built-in rechargeable battery, because it "supports all music files including 24-bit/192kHz lossless".
    AudioQuest Dragonfly Review : Affordable, Outstanding, Tiny DAC / Amp
    AudioQuest DragonFly USB D/A converter | Stereophile.com
    And an Android-specific USB DAC can support only 16-bit/44.1kHz:
    Android Open Accessory Protocol 2.0 | Android Developers
    If the AudioQuest Bumblebee is a standard USB DAC, while using with a PC or a Mac, the sound quality of the AudioQuest Bumblebee should be superior to the sound quality of the AudioQuest DragonFly thanks to a clean battery power.
    09-30-2012 08:44 AM
  4. DanBa's Avatar
    Yet another Stoner Acoustics UD100-based rig with FitEar TO GO! 334, the best in-ear headphone in the world according to Steve Guttenberg:
    FitEar TO GO! 334 --- Suyama's custom IEM, made universal!
    The best in-ear headphone in the world: The FitEar ToGo 334 | The Audiophiliac - CNET News
    stock Samsung Galaxy S3 > digital USB audio out >> USB OTG cable >> UD100 USB DAC >> Pico Slim amp >> FitEar TO GO! 334 IEM
    10-06-2012 12:26 PM
  5. DanBa's Avatar
    Samsung Galaxy S3 & Matrix Mini-i:
    Matrix Mini-i Balanced DAC | Headfonia
    stock Galaxy S3 > digital USB audio out >> USB OTG cable >> Matrix Mini-i >> headphones or amp
    10-11-2012 07:46 AM
  6. DanBa's Avatar
    Samsung Galaxy S3 & HeadAmp Pico USB DAC/amp:
    Pictures Of Your Portable Rig (part XV)
    stock Samsung Galaxy S3 > digital USB audio out >> micro-A male to type-A female USB cable + type-A male to mini-B male USB adapter >> HeadAmp Pico >> V-Moda M-80
    10-13-2012 08:11 AM
  7. DanBa's Avatar
    Custom Stoner Acoustics UD100 based on 24-bit ESS Sabre conversion chip:
    Tiny DAC, Big Sound Impression of Stoner Acoustics UD100 vs. ODAC
    Stoner Acoustics
    Samsung Galaxy S3 > digital USB audio out >> USB OTG cable >> custom UD100 cable >> amp >> headphones
    Samsung Galaxy S3 > digital USB audio out >> USB OTG cable >> HeadStage USB DAC cable >> RSA Protector amp >> JH Audio JH13
    10-21-2012 05:32 AM
  8. zachthebomb13's Avatar
    Hello all,
    I was directed to this thread to ask my question, and I hope someone here can help me out. I'm in the process of designing a way to dock our phones with our cars to not only stream audio, but also video. Android phones do this very well with hdmi, they just all do it differently. The GS3, like you all know, uses MHL, but not the normal 5 pin MHL, rather their 11 pin version. I'm sure there are many reasons why they used a new form factor. My question is, with the old 5 pin it would charge your phone at 500 mA, which isn't quite enough, and phones with the 5 pin mhl would slowly die. Is this different with the 11 pin? Does it charge at a higher rate? Do any of you have the new 11 pin mhl cable (not the 5-11 pin, rather just the 11 pin), and could you check this out for me real quick? I use the app below on my phone to check the rate that it charges at. Please let me know, this would really help me with my project. Thanks in advance.
    https://play.google.com/store/apps/d...2NjNzEuYm13Il0.
    10-24-2012 02:41 PM
  9. DanBa's Avatar
    If you use the micro-USB of the Samsung Galaxy S III, you could find some info at this link:
    10-27-2012 08:14 AM
  10. DanBa's Avatar
    About Android-specific USB audio:
    "As of now, the standard Android releases do not include USB host support. Samsung decided to add this feature on their own. The Android folks are working on a funky USB dock protocol that works over USB (sort of like what Apple does) that, frankly, most of us developers think is stupid. There is certainly a push to put USB host support for standard devices (like audio, keyboards, etc.) into the normal Android releases."
    [Pete Millett, design engineer from Apex Hi-Fi]
    Apex Glacier amp/dac review and appreciation thread
    10-27-2012 08:16 AM
  11. funkylogik's Avatar
    Hello all,
    mate try a thread titled "anyone with s3 HDMI cable?" ask them to help and give the link to the ampmeter app
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    10-27-2012 08:22 AM
  12. DanBa's Avatar
    Samsung Galaxy S3 & Apex Glacier:
    Apex High Fi Audio Glacier
    Galaxy S3 > digital USB audio out >> USB OTG cable >> Apex Glacier USB DAC/amp
    Galaxy S3 : 13,6 cm * 7 cm * 0,8 cm
    Apex Glacier : 11,4 cm * 6,5 cm * 0,9 cm
    10-28-2012 02:19 PM
  13. DanBa's Avatar
    Samsung Galaxy S III & planar magnetic Audeze LCD-2:
    http://www.head-fi.org/t/595071/android-ph...55#post_8873554
    stock Galaxy S III > digital USB audio out >> USB OTG cable (micro-A plug inserted in the Note II) >> RSA Intruder USB DAC/amp >> Audeze LCD-2 headphones
    "The LCD-2's sound phenomenal in balanced mode off the Intruder... Yum."
    11-20-2012 04:16 PM
  14. DanBa's Avatar
    The us$43 Samsung Galaxy S3 + Car Stereo Upgrade for WAaaY better sound quality!
    http://www.head-fi.org/t/639883/the-43-gal...r-sound-quality
    Galaxy S3 > digital USB audio out >> "USB OTG" cable >> Behringer UCA202 USB DAC >> car stereo amp >> car stereo speakers
    And so what are the results you ask?
    HOLY MOLY!
    Not only is the audio quality MUCH improved, but the sound is so CLEAN now. No clicks, burps, or any other weird background noises. Just straight CD quality background silence.
    Even my GPS voice sounds prettier. hahah
    Bass is tighter and deeper. Highs are more revealing. Everything is so much better that a novice could tell it sounds better.
    And yes, GPS navigation works perfectly. If I'm listening to Pandora or an MP3 and my GPS needs to talk, then my music will go several db quieter and GPS will speak up, then afterwards the music will automatically go back to full volume.
    Also, one thing I hated about Bluetooth was everytime I turned my car off for just a minute, when I would power it back on the Bluetooth would not consistently reconnect. Well, this USB-OTG has been very consistent for me so far. Music just picks back up where it left off at and is fairly quick to do so.
    Cons? Well, I haven't tested hands free calling yet. But I'm told it doesn't work with this USB-OTG to DAC configuration. Maybe there is a bluetooth solution for that. I dunno? And AOSP does not yet support DACs.
    Pros? Freakin everything.
    Pics are below.
    Here is the DAC and the USB-OTG cable:
    This is how you configure the DAC.
    You can probably also use the headphones output instead of the stereo RCA, but I didn't try it.
    I wired up my USB-OTG cable to my iBOLT dock. It comes up through my dash defrost vents.
    This is what the three connectors on the USB-OTG cable look like:
    Here is the DAC being wired up. I taped up the non-used RCA's to prevent anything bugging with them.
    I wrapped up the DAC with DUCT tape.
    Not sure how or why the pic is sideways. It looks normal on my desktop.
    Hid it behind my dash.
    Here is the USB-OTG cable with my iBOLT dock.
    The car stereo w/audio cable attached. Some car stereos have the 3.5mm connector in the back. Or a dual-RCA input. I'd prefer one of those to have a cleaner install. Maybe someday I'll upgrade my car stereo.
    And here is the finished product. My S3 docked, charging and outputing beautiful digital music!
    .." [CZ Eddie]
    12-08-2012 08:59 AM
  15. bakeri666's Avatar
    For the record, using a otg cable and usb microphone (and a usb recording app) I have managed to turn my s3 into a high quality digital recorder. I use it to get interviews for a local radio station.
    12-09-2012 06:09 PM
  16. winmod21's Avatar
    Another question: . . Do I get college credits for successfully completing this course thread?
    And if so, how many?
    Trees likes this.
    12-09-2012 09:53 PM
  17. DanBa's Avatar
    USB Audio Recorder PRO: "USB audio recording and playback now finally possible on Android devices!"
    "Supported are mono and stereo streams, 16-bit and 24-bit and any sample rate (up to 192kHz) that the device provides."
    https://play.google.com/store/apps/d...diorecorderpro
    USBAudioRecorderPRO
    Some USB DACs, like the FiiO E17, not working with stock USB audio software, can interwork with the Samsung Galaxy S3 and other Android devices using USB Audio Recorder PRO:
    music stored on Galaxy S3 > USB Audio Recorder PRO player > digital USB audio out >> "USB OTG" cable >> FiiO E17 >> headphones
    12-15-2012 06:35 AM
  18. meyerweb#CB's Avatar
    DanBa, when you talk about hands-free calling, do you mean Bluetooth? Have you tested handsfree, or Bluetooth yet
    If this doesn't interfere with my ability to do BT calling in my car, I'm all over this. I think I'll run a USB extension cable between the OTG adapter and the phone, though, so I can hide those bulkiy connectors behind the dash.
    12-16-2012 12:30 PM
  19. DanBa's Avatar
    I am just the messenger.
    You should ask directly CZ Eddie for that:
    The $43 Galaxy S3 + Car Stereo Upgrade for WAaaY better sound quality!
    meyerweb#CB likes this.
    12-20-2012 12:58 PM
  20. DanBa's Avatar
    Unique Melody Platform Pure 6 & Samsung Galaxy S3 using USB Audio Recorder PRO:
    Unique Melody Platform Pure 6 (PP6) - Discussion, Appreciation, & Tour Thread
    music stored on stock Galaxy S3 > USB Audio Recorder PRO player > digital USB audio out >> "USB OTG" cable >> Unique Melody PP6 > custom IEM
    "You have no idea how happy I am right now."
    12-23-2012 03:09 PM
  21. DanBa's Avatar
    24-bit / 96kHz lossless music and USB Audio Recoder PRO:
    https://play.google.com/store/apps/d...NvcmRlcnBybyJd
    Linn Records - Highwire
    music stored on Samsung Galaxy S3 > USB Audio Recorder PRO player >> ODAC >> amp >> headphones[COLOR="Silver"]
    12-25-2012 08:54 AM
  22. DanBa's Avatar
    USB audio at the Android Linux kernel space, USB audio at the Android Linux user space
    A USB audio source code:
    AlsaProject
    https://github.com/sgs3/GT-I9300_Ker.../usb/card.c#L2
    https://github.com/sgs3/GT-I9300_Ker...ster/sound/usb
    12-25-2012 01:13 PM
  23. DanBa's Avatar
    The compatibility list of Android devices / USB DAC is regularly updated at the following topic:
    02-23-2013 04:14 AM
48 12
