1. TanyaJayneP's Avatar
    Hi All,
    Had my S3 5 days now and really loving it having upgraded from the Google Nexus One.
    Only thing I'm having trouble with is using motion control to take a screen shot...is there a knack to this?
    Handbook says this motion control doesn't work with some apps, which ones does it work with (so I can try it on an app that I know it works with!)?
    Is it just me?
    Thanks
    TJ
    06-05-2012 04:39 AM
  2. Paul627g's Avatar
    Not sure about the motion control but stock ICS has screen shot built in and it should be no harder than holding Volume Down + Power.
    Sent from my Nexus S 4G using Android Central Forums
    06-05-2012 06:15 AM
  3. TanyaJayneP's Avatar
    Finally got motion control screenshot to work but tried the stock ICS method and definitely doesn't work.
    06-05-2012 06:35 AM
  4. blitz118's Avatar
    [YT]http://www.youtube.com/watch?v=xK908hWRy6o[/YT]
    06-05-2012 06:47 AM
  5. sandman132's Avatar
    Post some picture from your s3 so we can see quality plz.
    Sent from my EVO using Android Central Forums
    06-05-2012 11:21 AM
