That's pretty sweet.... If lengthy.
One thing that wasn't completely clear, can a person plug a USB hub into the MHL adapter and maintain USB host capability to a lot of peripherals *and* have the video output to the TV?
-Suntan
Unfortunately no. The way MHL works is its an either or proposition.
Depending on what cable is plugged in directly to the phone, the micro-usb port is either switched to the USB circuitry or the video mirroring circuitry. This is determined by the impedance of the cable that is hooked up to the phone.
Always interesting Goog'ling for my own videos and seeing where they show up!
Indeed the mutually exclusive nature of USB OTG and MHL connections is a pain, hopefully they can address that in the next revision of the MHL spec.
Worth mentioning though that you could use USB OTG and display stuff on an HDTV using Samsung's AllShare Cast dongle, although I expect latency might ruin that for gaming.
Finally, I do also use a Seagate GoFlex Satellite 500GB drive with my S3 and MHL, as the satellite is able to stream (and has it's own power supply for maximum portability).
You say lengthy, I say thorough
You don't need root for anything in the video
Yeah, I got that.
But if I wanted to use my DSIII controller *and* plug the phone into the TV, I'd need to run the controller wirelessly via the sixaxis controller app, correct? The GSIII doesn't natively recognize the DSIII controller via BT does it?
-Suntan
MHL Micro USB To HDMI Cable Adapter For Samsung AT&T Galaxy S3 i747 /Galaxy Note | eBay
MHL Micro USB to HDTV Adapter HDMI Cable for Samsung Galaxy S2 S3 i9220 i997 G14 | eBay
These MHL adapter are listed as being compatible with the S3. Can anyone here confirm them as being legit or should i just assume they're fake?
They may not be fakes, but they won't work with the S3. Those are the older ones that work with the S2/Note/everything else ever made with MHL, Samsung changed the pin arrangement in the S3 so they no longer work (grrr). Lots of honest sellers are listing them as compatible since they anticipated they would be, seeing as how MHL is meant to be a connection standard. Check the specific S3 one at Clove.co.uk and grab the model number and search for that (also check how it looks, since the appearance of the adapter is different also).
