1. jaekim717's Avatar
    i've never used a screen protector on my phones, usually feel they are too sticky/tacky. but with that said, this is an expensive purchase so was thinking of getting one to protect the screen. which do you guys prefer? the spigen Steinheil Flex HD Series or the phantom skinz, and why?
    the spigen seems to be high quality but only covers the screen whereas the phantom covers the front and back.
    any inputs will be greatly appreciated.
    06-18-2012 08:43 PM
  2. nkawal's Avatar
    Steinheil, hands down the best. Only screen protector i ever use. Phantom feels tacky.
    06-18-2012 11:38 PM
  3. DreamSTi's Avatar
    Don't get the flex if you don't like the tacky/rubberish feel. Any of the other SGP screen protectors will be hard and you can barley tell its there.
    I use SGP on all of my phones
    06-18-2012 11:47 PM
  4. jaekim717's Avatar
    thanks for the advise!
    if you read the comparison chart under additional info, they mention only the flex covers the entire screen of the sg3. i believe this is due to the curved screen:
    http://www.spigen.com/media/wysiwyg/...ison_Chart.jpg
    so which ones would you guys recommend then? crystal, fine, optics, etc? i've never used one and definitely do not one a tacky feel.
    06-19-2012 08:50 AM
  5. snoopyandroid's Avatar
    Ghost Armor is fantastic. I've used them on all my phones and even on my mac air. Check them out here. They protect the screen and doesn't turn blue or any other colour. Also, they are very smooth, it's very difficult to tell that you have a protector on your screen and NO, I don't work for them. Not sure if they have the S3 yet.
    http://www.ghost-armor.com/
    06-19-2012 09:11 AM
  6. jaekim717's Avatar
    oh damn seems they only have 2 options for the spigen right now, ultra clear and ultra flex, my bad!
    06-19-2012 10:58 AM
  7. chay03's Avatar
    I have had steinhil before. It was nice. You cant tell it was there. Then i went with the hype and tried ghost armor. i didnt like it. It got kind of wrinkley after a day. Creases started forming after a few days. So i ripped it off and threw it away. Now Ive got a cheapy ebay one and looks just as good as my steinhil.
    Sent from my SPH-D710 using Tapatalk 2
    06-19-2012 10:44 PM
  8. cwoms167's Avatar
    I always get the glass t screen protector. I live them because they are silky smooth and just feels solid. Its like having a backup screen on your phone
    Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
    06-19-2012 11:36 PM
  9. jaekim717's Avatar
    thanks for the advise all, got the spigen sgp ultra crystal. sounds like more of what i'm looking for and only 13$ on amazon with free shipping and no tax
    06-20-2012 10:54 AM
  10. badelhas's Avatar
    So, how is your screen protector, would you recommend it?
    Cheers
    08-07-2012 05:04 AM
