1. Soundtrack to Chaos's Avatar
    will this memory card work in the GS3? or do i need a different type? thanks in advance
    http://www.amazon.com/SanDisk-microS...cUvbUpU1869090
    06-20-2012 11:06 AM
  2. Cruiserdude's Avatar
    Yeah, that'll work just fine. It's a Class 4, which I got last year with my Charge, and its been plenty fast.
    06-20-2012 11:09 AM
  3. Soundtrack to Chaos's Avatar
    oh ok, thanks! but why is it so darn cheap? i think best buy sells these for over 30$ and amazon is practically giving them away for this price
    06-20-2012 11:54 AM
  4. mikesmith's Avatar
    Cause it's class 4 which is the slowest class out. Class 10 is the fastest. There is also a class 6.
    I would get a minimum of class 6 to use in the S3. Class 10 if you can get a good deal on it.
    Sent from my DROIDX (soon to be sent from my S3) using AC Forums App
    06-20-2012 11:57 AM
  5. socal's Avatar
    Because Best Buy is expensive. If you have a Fry's electronics in your area, they usually have way more selection and almost always better prices.
    06-20-2012 12:25 PM
  6. Soundtrack to Chaos's Avatar
    oh ok, thanks so much, now that i think about it, i dont really need a 32 gb card, i think ima get a 16 instead, but a class 10 16 gb card
    Amazon.com: SanDisk Extreme 16GB SDHC Flash Memory Card SDSDX-016G-X46,Black: Electronics
    would this be fine for the GS3?^
    06-20-2012 12:34 PM
  7. brewzer's Avatar
    No, it isn't a micro SD card.
    06-20-2012 12:40 PM
  8. Soundtrack to Chaos's Avatar
    dammit, can someone please help me find a 16 gb class 6 or higher sd card please, amazon searching isnt that good
    06-20-2012 12:42 PM
  9. brewzer's Avatar
    http://www.amazon.com/Samsung-MicroS...cUvbUpU1869440
    or if you want a USB reader for the card go with this one for .99 more...
    06-20-2012 12:45 PM
  10. mikesmith's Avatar
    http://www.amazon.com/gp/product/B00...cUvbUpU1869458
    I was able to get that one for $18.99 when Amazon had that SanDisk sale a week ago.
    06-20-2012 12:50 PM
  11. Soundtrack to Chaos's Avatar
    06-20-2012 04:32 PM
