Is the screen cover that comes with it worth anything? Or am I still buying a SGP or Rearth?
I'm surprised people are differentiating between the "quality" of these cases. I was looking at the clear/gray "Androdified" Cruiserlite. Is this one really that much better?
Ok pal now that the jokes are aside ....
This is my absolute hands down opinion on cases.
As we all remember black berry rubber cases ... They stretched out... Didn't protect really from a fall and stuck to your pocket ...
Then a new kind of rubber case came out and it was resin " tpu" ... This kind of case in my opinion is the best and tested thin protection for your phone.
Now your question .... YES there is a difference
I have had cheap ones that had holes that did not line up, some were thin in material and didn't have a good "bounce ". Some have to much wrap over the sides to the screen , some don't have enough.
I looked at the case you mentioned and I think its really cool and looks to have what you want in a protective case ... Only thing I saw was that the rocker was cut out and not covered over with a flexible thinner piece. That can either matter or not matter to you .... Depends on your line of work.
I have had the no name diamond print back tpu case that VZW sold on my Dinc for 2 years now .... The phone looks out of the box new and I have never had a screen protector on it. The phone was dropped kicked and in the elements. I don't go out of my way beat my phone up ... But I am not super anal either.
I hope I got some good info out with out being to long winded.
Seacrest out
