1. lordviper73's Avatar
    I got a Galaxy S 3 from T-Mobile and I want to used the hot spot app do I need to root it and if so will this void my warranty. T-Mobile charges $15 per month to use this application that is all ready in the cell.
    06-25-2012 09:52 AM
  2. snoopyandroid's Avatar
    Asking the same question in 3 different threads won't get you an answer any faster. You're just going to **** people off.
    1 thread with your question(s) and you'll get an answer.
    06-25-2012 10:28 AM
  3. DAS's Avatar
    It is my understanding that any device you root will void the warranty?
    I don't know for sure if it will, but that's my understanding. All of the advice I've received is that if you decide to go that route please be sure you're knowledgeable in what you're doing.
    06-25-2012 10:29 AM
