Kevin OQuinn
AC Team Emeritus
To each their own. There are self-powered DAC/amp setups that are smaller than the phone.
It's not like something this sized would totally cramp your style.
Click to view quoted image
Still, it is what it is. Personally, I have expensive Shure IEM that I use while on the go. As they are very efficient I get the background noisefloor static that the poster up above commented about on a couple of my gadgets, but I just use an inline volume reducer to cut the noise out.
When I'm at home, they sound a lot better with proper amplification. Something that the Wolfson DAC wouldn't change even if it was included on the US version.
Even so, I doubt a person would notice the difference if they were "on the go." The surrounding ambient noise is usually enough to negate any real world improvements. Then you're just left with perceived bias.
In any case, yeah it would be nice to have the brand-name DAC onboard, but something tells me the real world difference between the two has much more to do with placebo than anything else.
-Suntan
You're right that that particular amp is small, but it's still one more thing that someone has to carry with them and find a place for.
I'm with you that it would be much better sound, but I'm not sure the average person (me included, and I love good sound) would lug that around with them.
