07-20-2014 10:15 AM
35 12
tools
  1. pnizzle20's Avatar
    this may be a dumb question but whatever, does this have any effect visually? what exactly is it doing ?
    06-29-2012 03:41 PM
  2. jerseygirl's Avatar
    looks to me that the transitions and animations are shorter. Reminds me of how you can adjust the transition speed on a PPT presentation.
    07-03-2012 12:05 PM
  3. ccsilvercat's Avatar
    legend! thank you, this was driving me nuts!!
    04-04-2013 06:32 PM
  4. Robert Porter's Avatar
    First time I have dabbled with the settings, other than figuring out how to save the changes, it was very straight forward and the phone is rapid again now.
    Thanks for the tip
    Rob
    05-06-2013 10:42 PM
  5. Darren Proudlock's Avatar
    Am i missing something? Sure the window animation is gone but the apps dont load any faster , i just find myself staring at a black screen for a fraction of a second I thought perhaps with the animation gone would take some strain of the os but no , nothings changed except it doesnt look as pretty
    08-25-2013 03:17 AM
  6. harjotbk's Avatar
    wooowwwww
    Its working i've doin my phone as per instructions and its booommmm...
    Thank you for help me
    11-08-2013 02:13 AM
  7. greg8355's Avatar
    Can anyone tell me how to find "developer options" on my S3? I have looked through every menu and submenu under Settings and it is not there. Thanks,
    G
    12-26-2013 09:45 PM
  8. phoneaddict78's Avatar
    G
    On mine it's under settings towards the bottom.
    Sent from my LG-LS980 using AC Forums mobile app
    12-26-2013 11:19 PM
  9. GSDer's Avatar
    Sounds like you're running 4.3. In order to get into Developer options you have to go to Settings -> About phone and tap on the Build number several times.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
    Fixall7 likes this.
    12-26-2013 11:26 PM
  10. Fixall7's Avatar
    Thank you ...
    07-20-2014 10:15 AM
35 12
