mikezot
Root your device, install Root Explorer, navigate to /system/csc/feature.xml (make sure r/w is toggled, long press and open in text editor)
Edit the setting below to true. Reboot, then you will have the option to disable the shutter sound.
true
Sent from my rooted/modded/stock Samsung Galaxy SIII using Android Central Forums
I did what you suggested with my Sprint version of the Galaxy III and the option for Shutter sound is now there but I tried to turn it off and the sound is still there. Any thoughts?
