08-06-2012 02:15 AM
26 12
tools
  1. brava27's Avatar
    Main question is does wifi consume more battery than 4g? Or about the same?
    06-30-2012 10:07 AM
  2. Rev2010's Avatar
    No, wifi uses significantly less battery life than 4G LTE. If you're concerned about battery life or data usage it's a good idea to jump on wifi when you can.
    Rev.
    06-30-2012 10:11 AM
  3. brava27's Avatar
    Awesome just like blackberry. Makes sense. Thank you
    06-30-2012 10:13 AM
  4. Soundtrack to Chaos's Avatar
    ive been using wifi because i have sprint's 3g atm
    06-30-2012 10:13 AM
  5. NIKSTORM's Avatar
    What about speed ? On my Dinc 3g only I see night and day difference in speed. Will 4 g be faster than WiFi ?
    I doubt it , bit might as well ask.
    06-30-2012 10:14 AM
  6. Rev2010's Avatar
    Well wifi has a theoretically maximum bandwidth of 54 megabits but is more commonly around up to 36 megabits if the back end bandwidth is there. Wifi is often shared though as well so the speeds are almost never as good as wired speeds. On the flip side 4G LTE speeds also vary depending on location and the amount of people using it in the area.
    I'd done some tests and so far I've hit a whopping 3859 *kilobytes* per second download over 4G (I prefer Kilobytes over Megabits as it's easier to correlate to real world downloads). That is insanely fast! I am paying extra to my cable company for "boosted" speeds so I get up to 30 megabits at home with it more typically around 25 megabits max. That 4G LTE speed I hit blows past that! So 4G LTE I would say is very often way way faster than public wifi networks. If you have a home connection at 25 megabits and no one else is on your router downloading I would say the speeds could be faster or could be slower - that would depend on the 4G connection in your area.
    Sorry for the long winded response.
    Rev.
    06-30-2012 10:37 AM
  7. val31178's Avatar
    I think it will all depend on the wifi connection. If your on one that is being shared and used by many devices thats going to cut into the speed.
    06-30-2012 10:38 AM
  8. NIKSTORM's Avatar
    Rev.
    So you have no idea then .....
    Just kidding thanks for the great technical response. I use private WiFi at my house. How do I test connection speeds ? 3g , 4g , WiFi
    06-30-2012 11:09 AM
  9. tekhna's Avatar
    In the end, it's not going to matter. 80% of your battery use is going to come from the screen. You're just fiddling around the margins with wifi vs cell data.
    06-30-2012 11:25 AM
  10. firetruck41's Avatar
    I use the speedtest.net app from the Play Store, on my Droid X, or go to the Speedtest.net - The Global Broadband Speed Test website to check my computer connection speed.
    06-30-2012 11:31 AM
  11. vacanation's Avatar
    https://play.google.com/store/apps/d...roid.speedtest
    Sent from my SPH-D710 using Android Central Forums
    06-30-2012 11:33 AM
  12. Rev2010's Avatar
    I use speedtest as well. And you can change the result readout to Kilobytes which I prefer.
    Rev.
    06-30-2012 11:34 AM
  13. planoman's Avatar
    Rev.
    G wireless is 54 mbps but N is much faster. Having said that the wifi speed on this phone is much slower than a laptop using the same wifi. My phone does not even get close to the other devices getting wireless in my network. My LTE speed is much faster but I use wifi since it uses less power and does not count against my data although I have unlimited. I have 75 mbps internet at home with FiOS but my phone only hits about half that according to the speed test on wifi. Still plenty fast enough!
    06-30-2012 12:05 PM
  14. starsofthelid's Avatar
    Me too.
    I prefer the wifi at home, by once I leave the house, Sprint's 3G network CRAWLS.
    06-30-2012 05:11 PM
  15. raysun's Avatar
    If WiFi is available it will almost always be superior to your carrier data network in speed, battery life, and transmission costs.
    I get pretty good WiFi speeds on my 802.11n home network:
    Attachment 32743
    07-29-2012 08:16 AM
  16. capslock118's Avatar
    Is an android phone smart enough to have the cell and WiFi on at the same time to prefer the WiFi or is it best practice to go into airplane mode?
    07-29-2012 08:21 AM
  17. adelcastillo78's Avatar
    The Sprint SGS3 is. It has an built in feature called intelligent automatic connection. Not sure if is standard on all S3 of just Sprint's
    07-29-2012 09:18 AM
  18. funkylogik's Avatar
    all you americans should think yourselves lucky lol i get 9mb/s down MAX on the UKs fastest 3g network very cheap and unlimited though
    07-29-2012 09:39 AM
  19. Rev2010's Avatar
    When you turn on wifi it turns off data over the cellular. If you turn on airplane mode it turns off all antenna's so you can't use wifi or cellular.
    Rev.
    07-29-2012 10:08 AM
  20. capslock118's Avatar
    If we constantly complain then things will constantly improve
    07-29-2012 10:10 AM
  21. funkylogik's Avatar
    lol m8. dont get me wrong, 5-9mb/s is fine for surfing, i cant imagine what 20+mb/s is like lol. i dont envy the US prices
    07-29-2012 11:07 AM
  22. Rev2010's Avatar
    My home internet speeds are up to 25 megabits, I pay for boost service as well. I've done speed tests on my S3 connected to LTE and have gotten over 30 megabits a number of times. Quite funny that my phone beats out my home cable connection lol. Of course this is purely dependent on location as some areas the speeds are drastically different.
    Rev.
    07-29-2012 12:58 PM
  23. funkylogik's Avatar
    i dont have home broadband so 3g is my only link to the interweb lol
    07-29-2012 01:02 PM
  24. deanodrums's Avatar
    Sorry to be a bit of a pain here but i keep seeing LTE. What is that? I havent caught up in the world of shortening words yet. HAHAHAHA.
    I do know one thing,i dont even get 4g on my s3. Does that mean here in the uk we are behind?
    08-06-2012 12:23 AM
  25. NickLippert's Avatar
    4G LTE stands for long term evolution.
    08-06-2012 12:44 AM
26 12
