1. artofdesign's Avatar
    On my S2 Skyrocket the default music player controls were on lock screen when music is playing. How do I do this on S3?
    06-30-2012 06:30 PM
  2. okbow68's Avatar
    Like to know this as well.
    07-01-2012 03:15 PM
  3. artofdesign's Avatar
    Bump...
    07-05-2012 04:19 PM
  4. calcheese's Avatar
    I don't think you can.
    The only way is to disable pin or pattern lock and just scroll down the notification bar from the lockscreen..
    07-05-2012 06:24 PM
  5. mctl's Avatar
    I've been able to do that using the WidgetLocker Lockscreen app.
    After installation, it lets you add widgets, shortcuts, anything on the lockscreen as well as resize. Haven't found another app that easy to use.
    As an example, you have my current lockscreen, using the PowerAmp widget to control music.
    07-05-2012 07:19 PM
