07-18-2012 08:40 AM
85 ... 234
tools
  1. Dazo's Avatar
    A thought. Do you guys who have crap battery life have power saver turned off? It may be the difference between you and everyone else.
    Good question. I've had mediocre battery life lately (was awesome when I first got it).
    My power saver is turned off tho. Does it make much of a difference w it on?
    Sent from a different Galaxy using Tapatalk 2.
    07-16-2012 07:04 PM
  2. taylorz_412's Avatar
    Decent for some lte and WiFi but I have sync and auto brightness turned on with a bunch of accounts and what not
    Sent from my SCH-I535 using Android Central Forums
    07-16-2012 08:34 PM
  3. Dave_k605's Avatar
    Two battery cycles in.....couldn't be happier with the battery life.
    Sent from my SCH-I535 using Tapatalk 2
    07-16-2012 08:52 PM
  4. taylorz_412's Avatar
    Click to view quoted image
    3g or lte
    07-16-2012 08:54 PM
  5. Dave_k605's Avatar
    3g or lte
    About equal between 3-4g and wifi..I was pushing the phone hard, seems like it likes it rough...
    07-16-2012 09:49 PM
  6. trunkmonkey1972's Avatar
    It's all about what ur phone is doing during those 7 hours. settings》battery 》 will tell you what's eating power. Keep a close eye on 'free' apps. They like to stay busy doing nothing productive.
    07-17-2012 03:41 AM
  7. dfb8085's Avatar
    Mine was terrible also till I turned S voice off now its double what it was. I get around 15-20 hours
    07-17-2012 04:53 PM
  8. mikesmith's Avatar
    If you don't use CPU intensive apps or games then turn on Power Saving and check CPU Power Saving only.
    HUGE improvement in battery life for me. I was down to about 20%+ after 8 hours at work with mostly using tweetcaster, AC forum app, texting, and light Internet use. I had to charge the phone around noon to get me through the rest of the day.
    Today, I'm at 50%. Screen on time of 2hr 35mins.
    And there is NO lag, slowing down, or any other visible issue from turning the power Saving on.
    At 6pm after being 10hr 31mins off charger, I'm at 34% with a screen time on of 3hr 12mins.
    07-17-2012 05:00 PM
  9. Aadamgibson's Avatar
    I have an Android phone and have noticed that the battery life depends upon type of usage. My battery consumption is more when I am browsing sites on my android. There are some apps that consume more battery and that could be one of the reason that your battery drops so quickly.
    07-18-2012 05:24 AM
  10. MBSMD's Avatar
    I keep haptic feedback off - I'm thinking it's a battery killer for those of us who type a lot.
    I've just now turned on CPU power saving and screen power saving (but not the setting that flips black for white in the email app - hate that). We'll see how it does. It was doing pretty good without any of that before, so perhaps this will really help things.
    Either way, the standard battery on the GS3 is giving me what the Sedeio extended battery was giving me on my GNexus LTE.
    07-18-2012 08:40 AM
85 ... 234
