1. Typommier's Avatar
    Is anyone else having a problem where the notification sound for a text message doesn't play? I've checked all settings and can't seem to find a solution. Is anyone else experiencing similar problems?
    Sent from my Samsung Galaxy S3 using Android Central Forums
    07-04-2012 08:39 AM
  2. stilldvirus7479's Avatar
    having the same problem as of this time. while searching for a fix, i found an advise on doing a factory reset. i haven't tried it yet though. planning on getting it checked by samsung here. what about you? have you gotten it fixed?
    07-07-2012 01:00 PM
