1. GK3K's Avatar
    I use the line-in jack in my car's stereo to play my MP3's from my phone as I did with my EVO. I also use Pandora, TuneIn, etc.
    One annoying thing I noticed today is that when I plug the line-in cable into the headphone jack, the volume is automatically lowered about 25% before playback. The visual volume slider also appears on the screen momentarily.
    I suspect this is a safety feature Samsung introduced into the phone. For me, it's quite irritating as I have to turn the volume up to maximum every time after I plug-in. Otherwise, the volume is not loud enough on the stereo. Yes, I could just turn up the stereo's volume, but that seems silly. If I switch to radio, then the radio stations will be blasting out of the speakers.
    Does anyone know if there is a way to disable this function? I think when I owned an iPhone 3 (eek!) back in the day, it had separate volume levels for the speaker, headphones, etc.
    07-04-2012 10:37 PM
  2. Voice-Guy's Avatar
    It's going to be a few days yet before I get mine so I don't know if you can disable it. If you have Tasker you could set it up to go to a certain volume when you plug in headphones/line to your stereo.
    07-04-2012 11:40 PM
  3. Tkbredx's Avatar
    Never noticed that with my headphones but when I turn the volume up with headphones in it gives me an annoying little message that says volume this high can hurt your ears. its very aggravating. I am not stupid you don't have to warn me everytime I turn my volume up.
    GK3K likes this.
    07-05-2012 01:56 AM
  4. rpz3.14's Avatar
    Take a look at volume control+ in the play store. The free version allows you to change the various volumes (headphone, bluetooth, etc) independently.
    07-05-2012 08:18 AM
  5. GK3K's Avatar
    I'm already using Volume+ to boost the speaker audio. I find it to be to quiet when playing back videos.
    The headphone function lets you adjust the EQ, go past the maximum volume, etc.
    It doesn't have a feature like "set volume to max" which is what I was hoping for.
    07-07-2012 03:20 PM
