1. miketko's Avatar
    Hello all,
    Just wondering if anyone has successfully found an app to customize the LED on the S3. I want to be able to set the LED to flash diff colours text and email, phone calls etc. I tried light flow but it doesn't seem to work.
    Sent from my SGH-I747M using Android Central Forums
    kodree243 likes this.
    07-08-2012 09:01 AM
  2. BEARD GANG's Avatar
    Light flow does work..just takes trial and error as it has so many options but i gave up lol...
    Sent from my GT-I9300 using Android Central Forums
    07-08-2012 10:29 AM
  3. jeffreii's Avatar
    See the developer's blog regarding Light Flow on the AT&T S3:
    Light Flow - Blog
    Not sure which carrier you're on but this may be why - hopefully an update soon will fix it for us.
    07-08-2012 11:15 AM
  4. miketko's Avatar
    Thanks, I'm on Rogers but it's prolly the same issue
    07-08-2012 11:18 AM
  5. jeffreii's Avatar
    Yeah my bad it's not an AT&T issue but rather the USA version - specifically the Snapdragon S4 processor with LTE.
    07-08-2012 02:57 PM
  6. Tkbredx's Avatar
    Light flow is way to complicated. Didn't know what was happening because it wasn't working so I just went back too the Samsung given led notification lol
    07-08-2012 03:33 PM
  7. vedwardsiii's Avatar
    coming from Blackberry and using many different LED customization apps I needed one right away. Using Lightflow lite and it definitily has alot going on. I turned default LED off as well as all the LED notifications on Lightflow. Then went through and added one at a time until I felt I covered everything I needed. Some of the colors do not have a lot of contrast from each other but its pretty sweet either way. Also note there are a couple issues that Lightflow has already identified for GS3 US users. There working on them and all the detail is on there website.
    07-08-2012 10:47 PM
  8. pdl2mtl90's Avatar
    Exactly what I want to hear. Blackberry user as well that loves BeBuzz. Hoping they can get the issue resolved quickly.
    07-08-2012 11:01 PM
  9. jcp007's Avatar
    There could be something about TouchWiz that causes the issues with Light Flow. Supposedly, it works on ICS devices that don't have TouchWiz.Don't know how it reacts with the Sense skin on the HOX.
    07-08-2012 11:05 PM
  10. miketko's Avatar
    Bebuzz is a great app for blackberry. Hopefully they can resolve the issue with light flow soon
    07-09-2012 05:35 AM
  11. monkeyluis's Avatar
    I had tried lightflow as well but had problems. So I'll wait till they get fixed then try again.
    Galaxy S3 on AT&T.
    07-09-2012 06:32 AM
  12. jeffreii's Avatar
    Still waiting on Light Flow USA fix - however I have noticed that the LED on the SIII is not very bright and rather difficult to see in bright areas and/or if it's not at a good angle.
    I'm pretty sure it's going to be lackluster compared to BB but at least it's there!
    07-09-2012 08:59 AM
  13. miketko's Avatar
    Can't say I agree with you, LED seems strong on my S3. The again I've been on iPhone for the past year since leaving bb so having an LED again is amazing haha
    07-09-2012 09:04 AM
  14. PJnc284's Avatar
    Same here. It definitely beats the crap out of the poor excuse for an LED that the Thunderbolt had.
    07-09-2012 09:27 AM
  15. miketko's Avatar
    Even though I left bb in the dust they Def have some basic feature that ios and android are missing I.e led, profiles to name a couple
    07-09-2012 09:35 AM
