1. kaivorb's Avatar
    I tried doing a search (screen, off, screen+off) no luck.
    I want to have an app that will turn off the phone (or at least the screen), but the one I've been using on my EVO doesn't work here. I was using TURN OFF THE LIGHTS to turn off the phone, and it "kind of" works. It will turn off the phone...for about a second, and then the lock screen pops back on. It sits there for the alloted time, and then goes off.
    I am running ADW Launcher EX and I have Widget Locker on, but I doubt either of those are the issue. I thought I read somewhere that there was an ICS issue with being able to turn off the screen (but I've read so many forum threads lately, I can't place how accurate that memory is).
    Does anyone have an app that works for this? Or know of a setting tweak that would allow my app to work?
    I just want to be able to click a button/icon and have the phone turn off, so I don't have to click the physical button (just a personal choice).
    Thanks
    K--
    07-08-2012 03:45 PM
  2. GK3K's Avatar
    I used Scren Off on my EVO. When I installed it on my S III, pressing the button would turn the screen off, but it would quickly turn back on and then off again.
    The dev recently updated it and now it works without issue. I have the icon on the bottom right of my dock. Tap and pocket. I love it.
    https://play.google.com/store/apps/d...bm9mZmxvY2siXQ
    kaivorb likes this.
    07-08-2012 03:57 PM
  3. kaivorb's Avatar
    Perfect. Exactly what I wanted.
    Thanks.
    K--
    And I love the "old tv style" screen turn off. Just fun.
    07-08-2012 04:13 PM
  4. nwasquad's Avatar
    How did you get this to work on the GS3? I went to install it and it says "not compatible" with the GS3.
    07-12-2012 01:16 PM
  5. Suntan's Avatar
    I'd like to know this too. I'm guessing the dev took GSIII support off recently because he was getting a number of GSIII 1 star ratings. Hopefully a quick fix will have it back available.
    This would be great to have set to the double tap on homescreen gesture. That way, with the phone on a desk, one press of the home button turns it on and a double tap of the home screen would turn it back off.
    -Suntan
    07-12-2012 01:30 PM
