red_5ive
Re: Galaxy S3 Defaults to Headphone Jack, Car Defaults to Bluetoo
Cool - good tip on being able to connect to more than one BT device with the S3, I wasn't aware of that. I can actually use that in the house between my BT headset and my home system, so it looks like I'll be picking up the BT adapter for my preamp that I've been putting off. Thanks.
In the end I'm happy with the Beklin F4U037 unit I got that does both BT calls and audio/music. Granted it was more expensive, but since it's powered by the cig-lighter accessory so I don't ever have to worry about charging. My vehicle otherwise doesn't have BT, and the Motorola BT speakerphone I was using required charging. I much prefer not having to deal with that anymore so the extra $30 I spent over the F8Z492TTP was worth it to me.
I can fully confirm the functionality of the Belkin F8Z492TTP. It is now custom installed in my A3 with a direct power hookup and direct connection to the aux input. For power, I had to hook up a 12 volt car outlet behind the dash, insert a 12v to usb adapter, and splice the power cord from the factory transformer to a USB cable. Power is with a micro type H plug that Radio Shack does not have. They should give you a usb to type H cable with it.
Anyway, the Galaxy S3 will connect to two bluetooth devices at the same time...the Audi bluetooth and the Belkin Y37 Bluetooth. I put a shortcut button for bluetooth on my home screen which pulls up the options. You DO HAVE TO RECONNECT BLUETOOTH each time you get in the car, but you had to manually plug in the cable the other way.
When a call is made, the car bluetooth takes over with full steering wheel controls, and when it ends, the audio goes back on (I think automatically). Since I have constant power to the Belkin through the 12v, if you step away and then come back, you can automatically regain your connection, which is nice.
I did the modification to the Belkin where I broke it carefully open and pulled the metal innards that are purely designed to give it a feeling of mass. All that is inside is a teeny circuit board that must have cost $1 tops! Belkin lists this at $50, although it is half that on Amazon.
All in all, a decent solution to a frustrating problem. Sound is pretty decent.
