1. Buck-eye's Avatar
    Just got my SG3 a couple days ago and love it so far. One problem that I can't figure out. The arrows that tell you when your phone is uploading and/or downloading (under 4G LTE and WiFi) are flashing even when the phone is sitting idle. My Droid X never did this and I know it must be hurting my battery. How can I figure out what app is doing this and stop it.
    As I said above, I had the Droid X but didn't do much with it so I'm pretty much a noob. I looked around on the forums and know that I should go to "application manager" but I don't know which apps I can force stop without doing anything wrong. There are a lot of apps running on a phone like this. How do you know which one is causing the problem.
    I do not have the phone set to pull data (like email) it is all set to push and the data arrows are lighting up even when I am not receiving emails and texts.
    Any help would be greatly appreciated.
    07-11-2012 12:30 PM
  2. walcolm's Avatar
    an app or some apps are probably checking for updates.....
    07-11-2012 12:39 PM
