1. boogalu's Avatar
    Hey everyone
    Bought a Rock quicksand slim hard case and as I put it on and took it off I had noticed that it drags against the volume rocker and or the power button depending on which side you take off first. Is this going to be a problem later on or is it okay?
    07-11-2012 02:14 PM
  2. Uncle Louie's Avatar
    Hey everyone
    Mine does that too... I'm not going to end up using is. The inside edges are too sharp, and feel like they're gonna scratch the side. It's a shame, too; it's really a great looking case.
    07-11-2012 02:58 PM
