1. maxisgamez's Avatar
    Hey guys,
    I searched for Sound Effects but I can only find ringtones. Can someone point me in the right direction please...
    Thank you!
    07-12-2012 06:51 PM
  2. Mikest's Avatar
    This is only to turn on off the sounds
    Settings > Sounds > near the bottom
    Touch Sounds is the sound it makes every time you touch the screen
    Screen Lock Sound ... well that ones right in the name.
    As far as I know theres no way to change the stock sounds for those two.
    07-12-2012 08:34 PM
