1. Ricky Babalu's Avatar
    I have one of these Gorilla Gadgets for my soon to be retired Droid X. It has been a good battery for my X, and I just saw that they are offering a 4500 mAH one for the SIII. Only drawback is the supplied back is offered in white only, and it does not mention NFC capable ( I will assume it is not).
    Gorilla Gadgets Battery
    07-12-2012 08:41 PM
  2. NIKSTORM's Avatar
    On a vzw s3 what would I miss without it being nfc capable? Other than using tiles.
    And what about a case ?
    07-12-2012 09:03 PM
  3. rjenkin41's Avatar
    Why does the extended battery come with a cover? Does that mean the battery is bigger in size? Just wondering...in case I want to get one (and not have to get a new phone case in the process).
    07-12-2012 09:58 PM
  4. Ricky Babalu's Avatar
    Yes, unfortunately you will have to forgo a case.
    07-12-2012 10:12 PM
  5. Tkbredx's Avatar
    Was looking at this earlier. Hyperion has a couple. Cheap too on Amazon. 3800 should be enough to use the phone for a day heavily right?
    07-12-2012 10:14 PM
