1. tmags2's Avatar
    I want to turn off 4g and use only 3G. The only 2 choices are EHRPD and LTE. Is LTE 3G or 4g?
    07-13-2012 10:19 PM
  2. theween04's Avatar
    LTE is 4g
    07-13-2012 10:20 PM
  3. tmags2's Avatar
    So if I want to run 3G I should set it at EHRPD.
    Thanks
    07-13-2012 10:24 PM
  4. tmags2's Avatar
    I've tried both settings. 4G continues to come on. How do I turn 4G off and keep it off?
    Sent from my SCH-I535 using Android Central Forums
    07-13-2012 11:24 PM
  5. sicario666's Avatar
    What network are you on? Here's what I'm using. Primarily 4G but it switches to 3G when it needs to
    S3nt from Galaxy S3
    07-14-2012 12:50 AM
  6. SerfNuts's Avatar
    Download the phone info app on the market.
    https://play.google.com/store/apps/d...hone.PhoneInfo
    You can easily switch between 3/4G.
    07-14-2012 08:26 AM
  7. tmags2's Avatar
    I'm using EHRPD now. However, I've used both and 4G continues to come on. I know on my past android phones I could turn off 4G permanently. Doesn't look like we can do that with the SG3.
    07-14-2012 08:37 AM
  8. NotJustAPhone's Avatar
    Verizon removed the ability to switch to 3G only in their recent LTE phones. Just download the app Phone Info (mentioned above by another poster) and switch to CDMA auto (PRL) to keep it from using LTE.
    Attachment 30753
    Sent from my SGS III
    07-14-2012 08:43 AM
  9. tmags2's Avatar
    The phone info app from above worked great. Thanks
    07-14-2012 08:15 PM
