ansextra
I'm using the paid version of Apex and really like it. Apex and Nova are almost interchangeable as far as features are concerned I think.
Not exactly. But your contacts and info is backed up to your Google account.
If you brick your device. Then.unbrick it or get a new one, adding your Google Account will get your contacts back, info, email, whatever else.
The Launchers ha e an option to make a backup as well. Another thing, if you use Accuweather, it wont work on other Launchers. Only Touchwiz.
I don't have a Galaxy S III, but that's basic Android knowledge. :thumbup:
That's EXACTLY what I have set up.I use Apex. I tried Nova and for some reason the home page icons did not line up correctly. I am extremely happy with apex and use the weather widget from Fancy Widgets...
The lockscreen doesn't change unless you change it.Another newb question....how does the lockscreen look on Nova or Apex versus TouchWiz?
Do you have the phone yet?
Please clarify what you mean by icons not lining up..
Image of my primary home screen using Nova. 7 icons wide and 7 high. Normally i go for super clean but this time i decided to go for something different.
Also Nova does not control the lock screen.
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
