Great battery improvement
Zulu Warrior
59
16
I recently disabled s- voice on this thing, and my battery life has improved drastically. I never even really used s- voice, but I guess the services in the background still caused an intense drain. I just know that my battery life has gone up by a huge amount with that disabled. Has anyone else seen this?
Sent from my Samsung Galaxy S3, please excuse my brevity.
miketko
231
I wonder if restricting background data in background In settings would have the same effect
Sent from my SGH-I747M using Android Central Forums
LadiJae
392
20
18
Thanks,I just disabled mine as well.
I would like to use it but it doesn't work that great
~Jae, GS3 on Tapatalk~
radyoactive
882
18
I have S-Voice and Gestures turned off. Both are too gimmicky and are probably using up battery and system resources waiting for something to happen. I did leave the screen shot gesture on for the hell of it.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
I'm intrigued by this... Might have to try since I don't use s voice. Wouldn't mind a battery boost :)
sparksd
1,098
9
Probably something simple I am missing but after executing --
Settings > Application Manager (all) > S Voice > Disable.
How do you re-enable it? I go back into Application Manager after disabling it and S Voice no longer shows up (I did check under "All").
Dave
HOLLYWOODANT215
777
31
Dave
Good question I would like to no b4 I disable it
miketko
231
Dave
Strange. I'd like the answer to this as well
Scotlac
154
16
It's down at the bottom of the list. :)
Edit: Damn, you guys are fast....
Roboticz
311
24
Something else I've noticed is that you can use this "Disable" feature to get rid of the Cell Carrier bloatware as well! You may need to Uninstall Updates first...
Reactions: lv2bsilly
Zulu Warrior
59
16
Yeah, I really am loving this new battery life. I pulled it off the charger at 8:00 this morning, and it's now 8 at night. 52 percent battery life left, and I used it a fair amount today (youtube streaming on my Samsung tv, Web browsing, messaging, and in a crappy service area too. Really not too bad, I recommend giving it a try. As others have said, disable is useful for a lot of things, I've gotten rid of almost all boat ware from both carrier and samsung. I also have most gestures turned off, as most of them are gimmicky too. Hope you guys get as much of an improvement as I have!
akbarramadhani12
