miketko
Something else I've noticed is that you can use this "Disable" feature to get rid of the Cell Carrier bloatware as well! You may need to Uninstall Updates first...
How exactly do you get rid of the. Bloatware? Which ones are you disabling?
Sent from my SGH-I747M using Android Central Forums
