12-25-2012 12:22 PM
27 12
tools
  1. Pdelponte's Avatar
    Just to set the background the Samy GS3 comes with a 2100 mAh battery.
    I have been reading that it is possible to put a 2600 mAh battery in the GS3. Has anyone tried this? Will it break my phone or light it on fire?
    I have an AT&T GS3 if that makes any difference.
    07-19-2012 02:09 PM
  2. Pdelponte's Avatar
    im seeing some 3300 mAh batteries that claim they work in a SG3!
    I feel like my phone will explode if i use a 3300 mAh battery. Am i trippin?
    07-19-2012 02:12 PM
  3. Dave4321's Avatar
    A larger battery would work with a larger rear casing. Usually larger batteries come with them.
    07-19-2012 02:14 PM
  4. DESERTBURN's Avatar
    I have a 4300 mAH battery in my GS3.getting 28 hrs .
    07-19-2012 03:15 PM
  5. Ricky Babalu's Avatar
    4500 mAh battery:
    Gorilla Gadgets Battery
    You will have to do without a case.
    07-19-2012 03:16 PM
  6. LadiJae's Avatar
    My husband has the Hyperion extended battery 4000mAh with the pebble blue back, and it works excellent so far...I just ordered one myself in white.
    From Amazon
    Only thing, no case :o
    ~Jae, GS3 on Tapatalk~
    Curly62 likes this.
    07-19-2012 03:22 PM
  7. Pdelponte's Avatar
    awesome. Thanks for all the responses.
    Is there a large capacity battery that will fit in my GS3 without having to get a larger back cover?
    07-19-2012 03:29 PM
  8. camiller's Avatar
    None of the ones named in this thread make any mention of NFC. Since the NFC antenna is built into the original battery you may lose that functionality with generic aftermarket batteries. If NFC isn't important to you, you might not care.
    LadiJae - the link you provided didn't mention NFC, do you know if your husband's NFC still works with his extended battery?
    07-19-2012 03:47 PM
  9. wilfreb's Avatar
    i had one of those on my previows phone [GS2]
    and it made my GS2 look like an elephant.
    for my new GS3 i ordered an extra OEM battery and a dedicated charger insted, check it out
    2100mAh OEM Battery + Charger For Samsung Galaxy S3 III AT&T i747 Verizon i535 | eBay
    Wampa1 and Curly62 like this.
    07-19-2012 03:51 PM
  10. Kench33's Avatar
    Do you think these are legit? Its coming straight from China and there are always a bunch of knock offs.
    07-19-2012 04:11 PM
  11. InkedAdrenaline's Avatar
    What's nfc?
    Tapatalk'd from my Galaxy S3
    07-19-2012 04:26 PM
  12. Pdelponte's Avatar
    What's nfc?
    lol NFC is NBD BTW
    07-19-2012 05:59 PM
  13. jcp007's Avatar
    While the extra battery life is great, I have dropped my share of phones and now put a case on all of them. Battery life so far has not been an issue as I have a home, car and office charger. The battery life is pretty decent and I have yet to go below 50%
    07-19-2012 06:11 PM
  14. hobbsave's Avatar
    Mugen 4600 $99, do you think it's worth the it?
    http://www.mugen-power-batteries.com...tery-door.html
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
    07-19-2012 06:40 PM
  15. FishMeetFish's Avatar
    I would love to know too. I already charged my S3 2 times today and battery now is already down to 35%.
    07-19-2012 07:35 PM
  16. Mark_Henson's Avatar
    You need to find put what is sucking your battery life. I use GSam monitor and found the app that was killing mine, and now average 18 - 20 hrs a charge.
    07-20-2012 06:38 AM
  17. LadiJae's Avatar
    I just downloaded it
    07-20-2012 07:23 AM
  18. camiller's Avatar
    What's nfc?
    Near Field Communications.
    It is a very short range communication standard. It is what the Google Wallet app uses to communicate to a merchants paypass enabled point of sale device to let you pay for things with your phone. It is also used by Android beam/S-beam to initiate a connection between two phones.
    Some other neat things
    http://forums.androidcentral.com/htc...uses-apps.html
    07-20-2012 07:45 AM
  19. InkedAdrenaline's Avatar
    Thanks I Google it and the answers varies
    07-20-2012 12:03 PM
  20. Pdelponte's Avatar
    Just an update, Mugen-Power has a 2300mAh battery that fits in the phone without having to get a larger back cover. It's only a 10% bump up from the 2100mAh and I am not sure if it has NFC. If you want more power than 2300mAh it looks like you will have to get a bigger back cover.
    EDIT: The Mugen 2300mAh has NFC it can be found here: http://www.mugen-power-batteries.com...-iii-1747.html
    4424 likes this.
    07-20-2012 01:39 PM
  21. njperry's Avatar
    4,300mAh Extended Battery for Samsung Galaxy S III for $8 + free shipping!
    'm wondering if this is a legit battery. Anyone know?
    4300mAh Extended Battery with Blue Back Cover, FREE Shipping, 4300mAh Extended Battery with Blue Back Cover
    07-20-2012 05:02 PM
  22. Pdelponte's Avatar
    No idea, but since it probably makes the phone 50% thicker, im over it.
    njperry likes this.
    07-20-2012 05:06 PM
  23. Wampa1's Avatar
    I do the same. I had an extended battery for my thunderbolt and an extra standard one. Found I would never use the extended one because I hated the extra bulk. For the s3 I bought an extra oem battery and charger but the battery life is so good I don't find myself carrying around the extra one anyways.
    njperry likes this.
    07-20-2012 05:14 PM
  24. njperry's Avatar
    I wish there was a picture showing how much thickness it adds but you're probably right. It's just very tempting for only $8. Not sure I want to risk it frying my phone though.
    07-20-2012 05:56 PM
  25. wolfdemon268's Avatar
    Will this work with the cricket wireless version?
    12-25-2012 11:54 AM
27 12
