07-22-2012 04:20 PM
37 12
tools
  1. funkylogik's Avatar
    ...itl be interesting to see how much battery use comes from the app..
    07-20-2012 10:39 PM
  2. GK3K's Avatar
    with Lux, is the dimming and brightening smoother than android or does it still change in noticeable chunks
    I went into Lux's options and chose the Adjust Dynamically option. It's smooth, but not silky smooth.
    Still worth having the extra backlight, or less.
    Play around with the settings and let us know what you like.
    07-20-2012 10:40 PM
  3. funkylogik's Avatar
    yeah il try it tomorrow man. right now its pitch black dark lol (4.40am)
    07-20-2012 10:42 PM
  4. GK3K's Avatar
    I installed GSam Battery Monitor. I'll report back in a week and see if the increase in brightness is worth the toll it will inevitably take on the battery.
    07-20-2012 10:42 PM
  5. GK3K's Avatar
    Sounds good.
    07-20-2012 10:43 PM
  6. funkylogik's Avatar
    yeah but itl give a rough guide of how much battery the native auto adjust in phones uses
    07-20-2012 10:44 PM
  7. storino03's Avatar
    is there an apk to fix the color saturation on the galaxy 3? Sprint.
    07-20-2012 10:57 PM
  8. funkylogik's Avatar
    id say that would be a pretty phone-specific think to modify + not an android thing so i doubt it man but could be wrong
    07-21-2012 12:21 AM
  9. Jaimeg123prmt's Avatar
    That is just stupid. Why would they remove a feature that was in the galaxy s2?
    07-21-2012 08:19 AM
  10. GUARDiAN921's Avatar
    As far as the topic title, like a previous user said, only the international variants had that option. Was hoping to mess with them too on my Sprint GS3 variant. And as far as an app to decrease the brightness, I've used an app called Screen Filter by haxor industry. Haven't tried Lux Auto-brightness so if that dims it far enough for you then that should be fine. Just that if you need it even darker, Screen Filter can go as far as nearly pitch black. Used it back on my Epic 4G days and it still works fantastic on my GS3.
    07-21-2012 01:12 PM
  11. shon8052293's Avatar
    I Wish U.S Versions Had Screen Mode Option
    07-22-2012 04:07 PM
  12. rired48's Avatar
    Why don't you watch the movie and not whoever is checking their phone. The movies you go to must suck, 'cause I could care less If someone is just checking their phone and not talking on it. I mean really a forty or fifty foot screen and blaring surround sound and you are the cell phone ninnie
    Maybe YOU will remember his post the next time you go to the movies and get off your high horse.
    It's a rule of the establishment you're visiting. That's why you shouldn't do it. Oh, I forgot, the rules don't apply to narcissists like you... loser.
    07-22-2012 04:20 PM
37 12
