07-22-2012 04:49 PM
30 12
tools
  1. taylorz_412's Avatar
    Anyone? If so How much battery does it use ?
    Sent from my SCH-I535 using Android Central Forums
    07-20-2012 08:50 PM
  2. xliderider's Avatar
    Not me. Still using Screebl Lite to keep my screen on.
    07-20-2012 11:16 PM
  3. funkylogik's Avatar
    nope. i keep screen time-out at 10mins + iv always just been in habit of switchin screen off when not usin it
    07-20-2012 11:22 PM
  4. funkylogik's Avatar
    id imagine it uses a good chunk of power though since the front camera is on at end of each timeout
    07-20-2012 11:25 PM
  5. GK3K's Avatar
    I've had it on since day one. I haven't had it off, so I cannot comment on the battery use.
    Most of the YouTube reviewers that did test it with it off didn't notice a notable increase in battery life.
    07-20-2012 11:28 PM
  6. funkylogik's Avatar
    cool. i suppose its been optimised to use as little power as possible, the fact that the camera isnt tryin to create a picture etc. i might try it one day
    07-20-2012 11:31 PM
  7. taylorz_412's Avatar
    Yeah I might try it out
    07-20-2012 11:57 PM
  8. Soundtrack to Chaos's Avatar
    Doesn't really use any battery really, love the feature as well
    07-20-2012 11:59 PM
  9. nelonez's Avatar
    Not really useful to me... But I hear it's great...
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
    07-21-2012 02:09 AM
  10. jeffreii's Avatar
    It's not perfect - far from it - but it does work well and keep the screen on if you are looking at it. I doubt it makes a big difference in battery life but it definitely doesn't help battery life...
    I've turned off many of the gimmicky features, motions, etc. but Smart Stay is worth it to me.
    07-21-2012 09:32 AM
  11. anon(153966)'s Avatar
    Never tried it. Just not sure as I see a need for it. I'm sure it will 'adjust' battery life...
    07-21-2012 09:34 AM
  12. OWybPPgO's Avatar
    I'm with you on this. I love having it when I'm reading an article or something.
    07-21-2012 10:20 AM
  13. jimbo1mcm's Avatar
    I use Keep Screen. It allows you to keep any app you choose to stay open. You can select any app or all of them. Free. Works well. If you turn your phone off completely, you have to start it again.
    07-21-2012 10:24 AM
  14. Suntan's Avatar
    Turned it on day one. It works well enough to make it worth it.
    I like the feature. I have no problems with battery consumption.
    -Suntan
    07-21-2012 11:16 AM
  15. sicario666's Avatar
    I've had it on since day one. I like it since I have my screen time out set at 30seconds. No hits below the belt when it comes to battery life though. I won't be turning it off.
    S3nt from GalaxyS3
    07-21-2012 11:31 AM
  16. soccerdude2014's Avatar
    I have it on. It works just fine. Only a tiny affect on battery life.
    07-21-2012 12:59 PM
  17. hp10BII's Avatar
    I wanted it enabled but with the glasses it is not working at most of the time.
    Cool feature nonetheless.
    07-21-2012 10:25 PM
  18. funkylogik's Avatar
    lol i had wondered how it would handle glasses :-)
    07-21-2012 10:59 PM
  19. The_colombian's Avatar
    I use it and. Y battery lasts all day. I imagine it turns the camera on for a split moment and then shuts it off.
    Sent from my galaxy S III
    07-21-2012 11:56 PM
  20. f1nzup's Avatar
    I just turned it on the other day and there is no noticeable difference in battery life. Haven't really used the feature since I turned it on, but I know it's there when I need.
    Sent from my Samsung Galaxy S3
    07-22-2012 12:16 AM
  21. funkylogik's Avatar
    yeah m8 thinkin about it, thats all it needs to do.. when screen is about to time out, just turn on camera, focus it, and see if theres a pair of eyes i have time-out set to max so my screen has never timed out since gettin the phone
    07-22-2012 01:28 AM
  22. anon(848791)'s Avatar
    I have used it since day one. Luv it.
    07-22-2012 01:30 AM
  23. ejohnnyk's Avatar
    I love this feature and haven't noticed any power issues as a result.
    Doesn't work well in low light situations, but it definitely comes in handy.
    My iPhone friends tell me this is number one on their wish list of features.
    07-22-2012 02:30 AM
  24. funkylogik's Avatar
    iphone users just love their gimmicks though lol
    07-22-2012 02:43 AM
  25. funkylogik's Avatar
    ....glad ios6 wont be able to steal it though
    07-22-2012 02:44 AM
30 12
