1. PaulQ's Avatar
    If the LED colors you are picking are not matching the colors you see, this blog entry on the LightFlow site can be helpful. I came across it while reading up on the compatibility issues that they are having. Maps the words to the actual colors you are likely to see.
    >>> Known Issues
    Helped me a little with GoChat.
    unlmtdRW likes this.
    07-22-2012 06:34 PM
