At home the phone works perfectly well on wifi, sends and received data no problem.
At work it connects to the wifi network but does not send or receive data. I know the wifi is working as I currently have a client using it in the boardroom connected wirelessly.
nope, its a completely open unmetered wifi. complete separate internet connection to our wired work one.
i have the SSID and the wifi code, my phone connects. loses the 3g symbol and then no data is transferred. Browser doesnt work. Whatsapp doesn't work. the moment i go back to mobile data it works fine.
I had this very same thing happen on my home wifi (but static IP). I'm an IT Tech for a living and everything was setup perfectly. matter of fact, it worked the first day I set it up but then every time after that day it would connect but not send or receive. Eventually I just deleted the profile for my home network then re-set it up from scratch with the IP, subnet mask, WPA2 key, DNS, etc etc and then it worked and has been working perfectly ever since and it's been weeks now.
I would try deleting the profile, rebooting the phone for the heck of it, and then try connecting again. It's DHCP yes?
My work has a limited # of IP addresses assigned and sometimes they run out. The IP addresses are leased for an amount of time so even though they might not all be used at the same time, they are held for certain # of hours after they get assigned and then expire with inactivity. This could be happening.
goin_nil thanks for the suggestion but at the moment nothing is connected to the wifi its purely there for my mobile (noone else in the office has asked for the wifi code) and for when clients come in and need internet access.
ive just connected again and the two arrows are lit up orange and green but the 4 semi circles above dont fill in like they do when im at home
My office wifi requires our domain account authentication. I've maintained that. Internet works. But things like whatsapp and hangout doesn't work. I'm guessing push notifications etc. aren't working by default on my office wifi.
