06-20-2019 03:08 PM
56 123
tools
  1. Brandon Farabaugh's Avatar
    All you have to do is : Go to Settings-Sound-Volume-System , turn the system volume down the whole way , and you will not hear the start up or shut down sounds. You do Not have to root your phone. This is for the Galaxy S3.
    mariusfilip likes this.
    07-02-2015 09:34 AM
  2. diggifree's Avatar
    Yeah! This works for me. To configure all other sounds I am using Smarsound Profiles - ugly interface but works fine if you figured out how it works.
    02-12-2016 01:18 AM
  3. Shubh Agarwal's Avatar
    Before turning your phone off, turn on silent mode.Then when you will start it, it will not play any sound.It works for me.
    09-11-2016 11:26 AM
  4. Jen216's Avatar
    Nope kept saying failed. 😑
    02-11-2017 02:11 AM
  5. Jen216's Avatar
    Yes but the vibration is still there
    02-11-2017 02:13 AM
  6. benny_utzer's Avatar
    i found a solution [rooted] for Nokia 1 TA-1047:
    change the filenames of the following files to *.wav.dis (or something):
    system/CDA/600ID/Power-on-sound/boot.wav
    system/CDA/600RU/Power-on-sound/boot.wav
    system/CDA/600WW/Power-on-sound/boot.wav
    after reboot, no more sound.
    06-20-2019 03:08 PM
56 123
