07-06-2020 06:09 AM
35 12
tools
  1. pcguys's Avatar
    3.5 hours ago I took my phone off charger.
    I'm down 13% which equates to 3.7% per hour.
    I had 30 minutes of screen time (all of which was at 70% brightness).
    I push gmail and corporate exchange mail (touchdown).
    "Android System" held away for 14 minutes.
    What's up with this held-awake?
    Screen shots below.
    Is this normal?
    Thanks,
    Mike
    07-27-2012 09:48 AM
  2. Rev2010's Avatar
    I average 1% every 2.5 hours or so just standing by. Oh, and since that dude recommended turning off S-Voice, which I don't use anyway (or prefer Speaktoitassist), and others posted on how to disable apps you are not using, I am indeed now seeing an increase in battery life. Was fine before, but now it's lasting extremely well. I think prior to my tweaks I was getting about 1% drain every 2 hours.
    *EDIT - Oh, and I don't use push email, I manually fetch, so when it's just standing by it's really not doing anything in the background.
    Rev.
    07-27-2012 09:55 AM
  3. The Hustleman's Avatar
    This phone does about 4% an hour, but if I actually you know, USE IT it stands about 10% an hour.
    sent from my Samsung Galaxy S III on T-Mobile! goodbye Sprint!
    07-27-2012 10:00 AM
  4. HOLLYWOODANT215's Avatar
    I lose at least 12 percent a hour
    07-27-2012 10:03 AM
  5. pcguys's Avatar
    Sorry, I forgot to screen shot the remaining android system subs:
    Does this all look normal?
    07-27-2012 10:04 AM
  6. Rev2010's Avatar
    Wow, that's a lot of drain, definitely not normal. Read through this thread, bit long but it has some great tips:
    http://forums.androidcentral.com/sam...provement.html
    I already didn't have the S-Voice listening feature turned on, just the double press home button option, so I didn't think I would see an improvement but over time I now definitely see the improvement. Could also have been from the bloatware I disabled, quite awesome that the feature to disable a bunch of the apps is built right in and doesn't require one to root the phone.
    Rev.
    07-27-2012 10:06 AM
  7. pcguys's Avatar
    thx, will do. I already had s-voice not listening. I had read to disable it, but then turned it on because I didn't think that if it's not running, it could be hurting me, but I did disable it again.
    I now have vlingo launched on a double press of the home button, though I don't use it much at all.
    Mike
    kodybrannon likes this.
    07-27-2012 10:18 AM
  8. pcguys's Avatar
    It just occurred to me that I have weather on my lock screen, and a different weather provider widget on my home screen, so I took weather off my lock screen.
    I was also running life360 (a family locator service). I disable hourly location updating and instead will rely on me pressing the update button to find out where someone is when I'm interested (certainly not hourly).
    07-27-2012 11:01 AM
  9. jeffreii's Avatar
    It's really hard to say how much % drain per hour...because it totally depends on usage and settings/apps/etc.
    I think it's better to measure by standby time per hour - meaning minimal, if any, usage. For me I drain about 1% per hour under normal conditions if I am not using the phone.
    07-27-2012 11:05 AM
  10. jeffreii's Avatar
    It all looks pretty normal to me. 14% drain, in over 3 hours, with 30 minutes of screen on time seems quite fair.
    renaultr17 likes this.
    07-27-2012 11:09 AM
  11. Almeuit's Avatar
    I unplugged at about 6:20 this morning. I have about 32minutes for screen time and I've been texting some and streaming a little music (I'd say about 35min of music streaming) and mine looks like this...
    Edit - oh and Android Central Forums in the morning for about 10 or so minutes till I can clock in :P
    07-27-2012 11:24 AM
  12. The Hustleman's Avatar
    Rev.
    I should restate that.
    With highly minimal usage (couple texts, quick 1 minute phone call) I was draining that much.
    When totally not using it, I charge it and lose 3% over 8 hours as I slept
    sent from my Samsung Galaxy S WII on T-Mobile! goodbye Sprint!
    07-27-2012 05:17 PM
  13. Rev2010's Avatar
    That makes much more sense then. Before I did my tweaks I left it on overnight as a test at 100% charge and after 8 hours of sleep I woke up and it was at 96%, so that was 1% drain every two hours. Now I am getting a bit longer life than that but that was still excellent for standby IMO.
    Rev.
    07-27-2012 05:21 PM
  14. Dunbar42's Avatar
    The only thing that seems to be a rogue battery drain is if I go in and mess with sounds (ringtones, text sound etc.) That seems to be an ICS specific bug on Samsung phones. A couple of times my phone drained like 50% in 3 hours after I was messing with sounds. It's never good when you pick your phone up when it's been in standby for a while and it's warm LOL.
    07-27-2012 05:59 PM
  15. glassygurl's Avatar
    I usually last all day with this phone unless I'm constantly on the phone. I think I'm a pretty light/moderate user during workdays and when I leave my house at 8:30 with 100%, I usually go home with 40%ish around 6:00. If I use it more often during the day, I usually hook it up to my car charger during my ride home. Then, I just use it at night and plug it in when I sleep. Satisfied with S3 battery life, especially since I've used Thunderbolt before and that phone turns off in like 4 hours even with moderate use. Used to **** me off! But now I'm happy
    07-27-2012 08:34 PM
  16. PilotCline's Avatar
    I really do not know what the idle use is, but I average about 10-12% per hour. I consider myself a power user. I am constantly on it dorking around with something or other. It is my computer when I am at work, so that is why I use it so much. Screen usage is the battery killer for me, but not much you can do about that minus dimming!
    07-28-2012 10:42 PM
  17. dragoan's Avatar
    This was one thing that was bugging me as well. I am anal about battery drain and normally close apps as soon as I use them by long pressing the home button and remove all. I also go into task manager and force stop all of the games and apps that are shown in there and for good measure I also go into application manager and force close as many as I can in there although some just start up again that are part of the phone.
    When I first got the phone, overnight on standby I was only draining about 4-5% over 8 hours which was great but now I am averaging 1-1.5% per hour. Over 8 hours I am averaging loss of 10% battery. Not sure if due to so many games and apps downloaded and installed but thought I "stopped" them. Not sure what else I can do to get back the original 4% decrease over 8 hours.
    08-12-2012 04:55 AM
  18. pcguys's Avatar
    If you download gsam battery monitor , it will give you very specific data about what is eating ur battery.
    ---Sent from the most advanced android mobile super-computer on the planet: the Samsung Galaxy S3 on AT&T, featuring simultaneous voice & data and speedy 4G!!!
    08-12-2012 05:48 AM
  19. Lanhoj's Avatar
    I thought the SIII battery was suppose to be a beast, no? Or at least for Samsung...
    I get the same drain per hour (about 10%) as a heavy user on my 9 month old launch GSM GNex with the stock battery.
    Hopefully the Nexus 4 will do better.
    08-12-2012 07:20 AM
  20. The Hustleman's Avatar
    If you're one of those users that leave the phone on doing nothing so they can show orf an extremely high screen shot, it is.
    But if you actually use your phone, then don't expect more than 12 hours of usage
    08-12-2012 09:00 AM
  21. pcguys's Avatar
    sent from my Samsung Galaxy S3 on T-Mobile! goodbye Sprint!
    I smiled when I saw your sig about leaving sprint.
    2 years ago I loved sprint when I left ATT because they were dropping all my iphone calls.
    I just went back to ATT because they really improved their network in Philly (I did lots of testing with my friend's iphone 4S before I switched back).
    Sprint downloads degraded soo much in the last year. I was getting only like 87 kbps down.
    On ATT I'm getting 2-5 megs down on HSPA+ pretty much all the time!
    08-12-2012 09:10 AM
  22. The Hustleman's Avatar
    Yeah it's disgusting how Sprint's speeds have downgraded.
    At this point now I wish I stayed, they actually rolled out LTE here and I could have had this phone on LTE.
    When I get a new job and some money though I will be paying the termination ETF and coming back.
    I miss Sprint.
    Can't get a GOOD signal in my home with at&t, t-mobile, but Sprint and Verizon were exceptional in this aspect.
    I guess it's the advantage of CDMA.
    but I do like the versatility of gsm in the fact that I can switch a SIM and not worry about the carrier.
    08-12-2012 09:15 AM
  23. azharisadig's Avatar
    Iam using my phone mainly for internet and calling.. here is my battery usage after 11 hours and 38 m. Also when it reach 4...
    Sent from my GT-I9300 using Android Central Forums
    08-12-2012 11:56 PM
  24. pcguys's Avatar
    Thanks, that looks similar to what I got last night with 4 hours of screen time.
    08-13-2012 06:35 AM
  25. Wnrgway's Avatar
    When I have a good signal I lose about 1-2% per hour on idle. When I leave work after a 9 hour workday with minimal use I'm generally at 80%.
    Of course on rare occassions, like this morning, the phone wakes itself up and the screen stays on until I put it to sleep manually. It happened this morning and I burned through 20% in a couple hours. The only reason I noticed was the heat from the phone in my pocket.
    08-13-2012 09:20 AM
35 12
Tags for this Thread
