1. rebelman087's Avatar
    When I turn on the music player, the first song played will only play 15-30 seconds before skipping to the next song. Has anyone else had this problem or do you know what to do to fix it?!
    Thanks,
    Josh
    07-29-2012 04:12 PM
  2. scorpiodsu's Avatar
    Haven't noticed that but I just wanted to make a recommendation to try power amp. By far the best music player I have used and I've tried nearly all of them.
    Sent from my Galaxy S III
    07-29-2012 04:15 PM
  3. afv123's Avatar
    did you ever solve this issue? I have the same problem, but not just with first song- so often that's its a pain in the ****, with no discernible pattern, the player will advance to the next song in the middle of playing a song. cant seem to find an answer.
    10-24-2013 10:50 AM
  4. GSDer's Avatar
    afv123,
    Insufficient information...
    - what music player are you using?
    - is your music on the internal memory, SD card or in the cloud?
    - do you have any music in the Google Play Store or Amazon Store? If so, does that music play normally through their players?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    10-24-2013 04:05 PM
  5. AxlMyk's Avatar
    Mine does it too. I just ignore the problem, as I don't believe Sammy or Googlie will do anything about it.
    10-25-2013 10:16 AM
