leftyman
Where do I find my clipboard? I can copy to clipboard but don't know where to find it after that.
Sent from my SCH-I535 using Android Central Forums
If you long press in a text field (anywhere that you want to paste copied information..email text etc..) two options should pop up one is paste the other is clipboard. tap clipboard and it will open.
Everything that has been previously copy and pasted should be there. Long press each one individually and different options will be made available. Chose delete from clipboard.
After clearing the clipboard the ability to copy was available again after selecting the text with the blue cursers.
