1. jaymzb0nd's Avatar
    I know Titanium Backup is awesome but it's only good for non rooted phones. I just received my replacement S3 and don't want to deal with having to choose all my sound and notification options again for the different settings and apps.
    08-06-2012 07:54 PM
  2. Srambo217's Avatar
    You mean rooted? TiBU only works if you're rooted.
    I suggest you don't restore backups from one device to another, regardless if they're the same model or not. This can often cause force closes and issues within apps/settings.
    Basically, it's better to restore everything from scratch and start with a clean plate. This stuff happens, and by the time you get the work around ready to go you could have already manually corrected your settings.
    Sent from my SCH-I535 using Android Central Forums
    08-06-2012 08:14 PM
  3. jaymzb0nd's Avatar
    Yes I meant to say TiBU only works with rooted. Thanks for the advice.
    08-06-2012 08:40 PM
  4. johnj2803's Avatar
    How about your app data? Like my fuelogs or fame progress?
    Sent from my Samsung Galaxy S3 using Tapatalk2
    08-06-2012 09:00 PM
