1. jawzforlife's Avatar
    Just got my GS3. This is my first Android phone (moved over from blackberry).
    I want my phone to have sound AND vibrate when I get a call and text message.
    Works when I get a phone call, but when I get a text all I hear is my sound with no vibrate.
    What am I doing wrong?
    08-08-2012 11:50 AM
  2. Soundtrack to Chaos's Avatar
    Open your messaging app and hit the button to the left of your home button and open your settings and you will see it at the bottom of the settings menu Attachment 33895
    Dizzo1992 likes this.
    08-08-2012 12:08 PM
  3. Soundtrack to Chaos's Avatar
    And remember if you don't have your system volume on you won't hear the notification sound anyway so always have your volume on
    jawzforlife likes this.
    08-08-2012 12:09 PM
  4. jawzforlife's Avatar
    thanks, got it now
    08-08-2012 12:10 PM
  5. cooliosam's Avatar
    What OS version are you running? I don't have the vibrate option nor those emergency message options.
    Look at my screen shot. My menu just ends with Select Ringtone. No vibration setting...
    08-24-2012 11:31 AM
