xKrNMBoYx
You need to use your vocabulary a little better. My opinion on build quality isn't the material but how it is put together. Just because an item is made of plastic doesn't mean it's build quality sucks. For example many DSLR cameras are made of plastic (although hard abs).
Plastic gives flexibility and lightness. If you remove the battery on the S3 it feels like it is 50%+ lighter. This means the phone is built to be light. Technically the iPhone 4 is also plastic except the gorilla glass on the back and face of the phone. The older iPhone's had plastic backs and not much people complained then.
Any screen will scratch, especially if you don't take care of it. You may think you baby your screen, but you might just be imagining that. Purchase a screen protector prior to purchasing the phone. Or install the screen protector before you set up the phone for the first time. You could always use a cover also. You really shouldn't get scratches on a phone's screen unless you keep your keys in the same pocket as your phone (why not just put it in the other one), you use it with dirty hands, and other small things.
If you still are worried about the plastic build, purchase a metal battery cover/casing for the phone, or think of a metal bumper.
