1. pcguys's Avatar
    ---Sent from the most advanced android mobile super-computer on the planet: the Samsung Galaxy S3 on AT&T, featuring simultaneous voice & data and speedy 4G!!!
    08-12-2012 07:08 AM
  2. jeffreii's Avatar
    You had the screen on for all 20 minutes. Considering that, 4% drain is totally normal.
    Also that's your first 4% which means you might not have started at 100%. When you take the phone off the charger it might immediately drop to 98 or 99% due to smart charging protocols.
    08-12-2012 09:27 AM
  3. pcguys's Avatar
    Ok. Thanks.
    4% in 20 minutes means 100% in 8.3 hours. I guess that's about right, and the people here boasting about 24 hours are not using it 100% of the time.
    Mike
    08-12-2012 09:30 PM
  4. funkylogik's Avatar
    Ok. Thanks.
    Mike
    yeah exactly man. it depends on the screen brightnes and what youre doin on the phone while its on but your battery seems fine
    08-12-2012 11:22 PM
